Cabasse
Cabasse Rialto Wireless Powered Bookshelf Speaker (Pair)
Regular price $3,999
Sale price $3,999 Regular price $4,999.00
Save 20%
1 of 15
Cabasse
Save 20%
Wired, Wireless
The Cabasse Rialto is a powered wireless bookshelf hi-fi system designed as a true bridge between high-fidelity sound and modern connectivity. Inspired by Venice’s iconic Rialto Bridge, this system unites classic Cabasse acoustic expertise with connected technologies developed over the past decade. The result is a complete, compact stereo system that delivers dynamic, high-resolution sound with minimal setup.
Housed in a pair of connected active speakers with smooth, rounded lines inspired by the Cabasse Murano, Rialto integrates amplification, streaming, room correction, and tactile control into an elegant bookshelf format. Just add music and enjoy a refined yet powerful listening experience.
Key Features
  • Fully active wireless bookshelf speaker system with integrated amplification
  • Tri-coaxial driver architecture for coherent imaging and natural sound reproduction
  • Patented HELD high-excursion woofers for deep, controlled bass with very low distortion
  • DEAP digital signal processing for optimized driver and amplifier synergy
  • Built-in color LCD touchscreen with rotary volume control and album artwork display
  • Automatic room calibration with built-in microphone and app-based fine tuning
  • Wi-Fi, Ethernet, Bluetooth, and TV connectivity for music and home theater use
  • Multi-room compatibility with all Cabasse connected systems
Sound and Use Case
Despite its compact size, Rialto delivers remarkable dynamics and presence for a bookshelf speaker system. Vocals are clear and forward, instruments fill the room with scale and realism, and high-resolution recordings retain their full precision and impact. This performance is made possible by a combination of Cabasse acoustic innovations and advanced digital processing.
The HELD woofers are engineered for long excursion without the voice coil leaving the magnetic field, allowing powerful bass reproduction with minimal distortion. Cabasse’s long-refined coaxial technology aligns all drivers on the same axis, ensuring sound radiates from a single point for improved coherence and natural imaging.
Rialto is equally suited for music and TV use. A dedicated TV input delivers a dynamic stereo experience for movies, and volume can be controlled directly from a compatible TV remote thanks to integrated eARC functionality.
Design and Control
The main speaker features an integrated touch-sensitive display that provides intuitive, app-free control. Users can adjust volume, switch sources, and manage radio presets directly from the speaker. The full-color LCD screen displays album artwork during playback and evolves over time through regular software updates.
Available in white or black finishes, Rialto is designed to blend seamlessly into a wide range of interiors. A carbon fiber coaxial midrange-tweeter is framed by brushed aluminum trim, while a chrome-finished base gives the speaker a light, floating appearance. A magnetic metal grille completes the clean, sophisticated design.
System Type Powered wireless bookshelf stereo system
Maximum Volume 121 dB peak stereo
Frequency Range 30 Hz to 27,000 Hz
Midrange Tweeter Drivers 13 cm BCI coaxial midrange x 2
Woofer 17 cm HELD woofer x 2
Amplification per Speaker Treble 300 W RMS / 600 W peak, Midrange 300 W RMS / 600 W peak, Bass 450 W RMS / 900 W peak
Total Amplification System Treble 600 W RMS / 1,200 W peak, Midrange 600 W RMS / 1,200 W peak, Bass 900 W RMS / 1,800 W peak
DAC 32 bit / 768 kHz
Connectivity Ethernet, Wi-Fi, Bluetooth, Optical SPDIF, Analog RCA, USB, TV input
Audio Formats MP3, AAC, WMA, AIFF, FLAC, ALAC, Ogg Vorbis, DSD 64 and 128, WMA Lossless
Room Calibration Automatic calibration with built-in microphone
Multi-Room High-resolution multi-room compatible
Dimensions 26 x 20.6 x 23.9 cm / 10.23 x 8.11 x 11.53 inches
Weight 19.5 kg / 42.99 lbs
What’s in the Box
  • Cabasse Rialto powered wireless speakers (pair)
  • Power cables
  • User documentation
