Cabasse
Cabasse MURANO ALTO Floorstanding Speakers - Each
Regular price $4,999
Sale price $4,999 Regular price $4,999.00
1 of 6
Cabasse
Cabasse Murano Alto is a 3-way floorstanding speaker built for demanding audiophiles, combining Cabasse reference-derived coaxial technology with powerful bass capability. Assembled and tested in Cabasse French workshops, Murano Alto uses the BC13 coaxial tweeter-midrange, a key element of the TC23 triaxial loudspeaker architecture found in Cabasse reference systems, paired with dual 17 cm 17ND36 bass drivers and a tunable port system for flexible in-room performance.
Key Features
  • 3-way floorstanding speaker designed for high-end stereo listening
  • BC13 coaxial tweeter-midrange for tonal fidelity and realistic soundstage presentation
  • New aluminum waveguide designed to work with the Murano Alto bass driver
  • Dual 17 cm 17ND36 bass drivers with a concave honeycomb-structure cone for rigidity and damping
  • Three long curved ports with optional port plugs to fine-tune bass output based on room acoustics and placement
  • Designed and verified in Cabasse French workshops
Sound and Use Case
Murano Alto is designed to deliver tonal fidelity without added coloration, with depth and realism in the soundstage. The BC13 coaxial tweeter-midrange is intended to keep timbre consistent and reduce listening fatigue, while the dual 17ND36 bass drivers and triple-port loading are designed to provide bass that is fast, deep, and controlled. Port plugs allow you to adjust the bass balance, either emphasizing bass power or focusing on deeper extension depending on placement and room response.
Model Cabasse Murano Alto
Speaker Type 3-way floorstanding speaker
Number of Ways 3
Coaxial Tweeter-Midrange BC13
Bass Drivers 2 x 17 cm 17ND36
Crossover Frequencies 800 Hz to 3500 Hz
Sensitivity 89 dB (1 W / 1 m)
Nominal Impedance 8 ohms
Minimum Impedance 3.4 ohms
Rated Power 175 W
Peak Power 1200 W
Port System Three long curved ports with optional port plugs for bass tuning
Dimensions (H x W x D) 102.6 x 27.5 x 37.5 cm
Weight 28 kg
