Cabasse
Cabasse MINORCA MC40 Bookshelf Speakers - Pair
Regular price $1,999
1 of 7
Cabasse
The Cabasse Minorca MC40 is an ultra-compact 3-way speaker designed for music lovers seeking precision, realism, and a spacious soundstage from a small cabinet. Incorporating Cabasse SCS (Spatially Coherent Source) coaxial technology, Minorca MC40 pairs the BC10 coaxial midrange-tweeter with a Duocell cone woofer to deliver a level of scale and emotional impact often associated with larger loudspeakers.
Key Features
  • Compact 3-way speaker design built for high-fidelity stereo listening
  • SCS (Spatially Coherent Source) coaxial technology for coherent imaging and stable spatial presentation
  • BC10 coaxial midrange-tweeter developed using solutions implemented for Cabasse La Sphère
  • 17 cm Duocell diaphragm woofer designed for light, rigid, and well-damped bass performance
  • Variable slope crossover filters tuned using on-axis and 360 degree anechoic measurements
  • Designed for shelf placement or use on compatible stands
Sound and Use Case
Minorca MC40 is designed to deliver a precise, realistic presentation with a spacious soundstage from a compact enclosure. The BC10 coaxial midrange-tweeter is intended to preserve timbre fidelity and depth without artifice or listening fatigue. The Duocell woofer is engineered to support live-sound dynamics through a lightweight, rigid diaphragm and motor behavior intended for speed and control.
Cabasse tuning for Minorca MC40 incorporates on-axis and 360 degree measurements to manage directivity and total radiated power, then refines crossover behavior through listening sessions in rooms with different acoustics. This approach is intended to preserve the intrinsic qualities of the coaxial drivers while maintaining consistent in-room balance.
For placement, Minorca MC40 is designed to work well on a shelf or on a stand. Cabasse floorstands for bookshelf models are available in matte black or matte white and are designed to conceal cables and provide stability for speakers up to 50 kg.
Model Cabasse Minorca MC40
Speaker Type Compact 3-way speaker
Number of Ways 3
Coaxial Midrange-Tweeter BC10 coaxial: 12 cm ring and 2.7 cm dome
Woofer 1 x 17MD18LB1 Duocell (17 cm)
Crossover Frequencies 900 Hz to 3200 Hz
Bandwidth 65 Hz to 23,000 Hz
Sensitivity 89 dB (1 W / 1 m)
Nominal Impedance 8 ohms
Minimum Impedance 3.3 ohms
Rated Power 75 W
Peak Power 550 W
Placement On a shelf or on a stand
Dimensions (H x W x D) 40 x 23 x 28 cm
Weight 8.5 kg
