Cabasse
Cabasse JERSEY MC170 Floorstanding Speaker - Each
Regular price $699
Sale price $699 Regular price $999.00
Save 30%
1 of 12
Cabasse
On sale
Regular price $699
Save 30%
The Cabasse Jersey MC170 is a 3-way floorstanding speaker designed for rich and ultra-dynamic sound reproduction. It combines the finesse of a coaxial midrange-tweeter with the density and precision of two high-powered 17 cm woofers, delivering a stable, realistic sound image that stays consistent across the listening space.
Key Features
  • 3-way floorstanding speaker design for full-range performance
  • 2-way coaxial midrange-tweeter for coherent imaging and natural timbre reproduction
  • Dual 17 cm large-extension woofers engineered for bass extension with low coloration
  • Vertical port design that radiates sound 360 degrees
  • HDSE filters based on on-axis and 360 degree anechoic measurements to control directivity and total radiated power
  • Designed for surprisingly easy setup and consistent sound in all directions
Sound and Use Case
Jersey MC170 is built for listeners who want scale, impact, and a wide soundstage from a floorstanding loudspeaker. The coaxial midrange-tweeter is intended to improve depth and realism of the sound image for both two-channel listening and home cinema. The dual 17 cm woofers are designed with a rigid basket structure and a low resonant frequency to support extended bass output while limiting coloration.
Cabasse measurement and tuning protocols account for both direct and reflected energy to keep the overall presentation stable and evenly distributed in-room, supporting a wide listening area with consistent tonal balance.
Model Cabasse Jersey MC170
Speaker Type 3-way floorstanding speaker
Number of Ways 3
Woofers 2 x 17 cm (17TN20)
Midrange and Tweeter 2-way coaxial (10T15MC coaxial)
Bandwidth 57 Hz to 20,000 Hz
Crossover Frequencies 700 Hz and 3600 Hz
Sensitivity 90 dB (1 W / 1 m)
Nominal Impedance 8 ohms
Minimum Impedance 3.2 ohms
Rated Power 100 W
Peak Power 700 W
Placement Floorstanding
Dimensions (H x W x D) 99 x 21 x 30 cm
Weight 15 kg
