Cabasse
Cabasse JAVA MC40 Floorstanding Speakers - Each
Regular price $1,399
Sale price $1,399 Regular price $1,999.00
Save 30%
1 of 7
Cabasse
On sale
Save 30%
The Cabasse Java MC40 is a floorstanding speaker built for listeners seeking a more precise, realistic, and spatial high-fidelity experience. Using Cabasse SCS (Spatially Coherent Source) coaxial technology, Java MC40 combines a BC10 coaxial midrange-tweeter with two Duocell cone woofers to deliver scale, speed, and controlled dynamics with strong emotional impact.
Key Features
  • 3-way floorstanding speaker designed for high-fidelity stereo and home listening
  • SCS (Spatially Coherent Source) coaxial technology for coherent imaging and stable soundstage
  • BC10 coaxial midrange-tweeter developed using solutions implemented for Cabasse La Sphère
  • Dual 17 cm Duocell cone woofers designed for light, rigid, and well-damped bass performance
  • Designed for timbre fidelity without artifice or listening fatigue
  • Available finishes: all black, white lacquered, black lacquered
Sound and Use Case
Java MC40 is designed to present a spacious, realistic soundstage with coherent imaging from its coaxial midrange-tweeter array. Cabasse describes the BC10 as delivering timbre fidelity with depth and realism while avoiding listening fatigue. The dual Duocell woofers are engineered to support live-sound dynamics, combining a lightweight yet rigid diaphragm with long-stroke motor behavior for bass that is intended to be both lively and precise.
This model is designed for floor placement in dedicated stereo systems where scale, impact, and a stable in-room presentation are priorities.
Model Cabasse Java MC40
Speaker Type 3-way floorstanding speaker
Number of Ways 3
Coaxial Midrange-Tweeter BC10 coaxial: 12 cm annular-dome, 2.7 cm
Bass Drivers 2 x 17MD18LB1 Duocell
Crossover Frequencies 900 Hz to 3400 Hz
Bandwidth 59 Hz to 23,000 Hz
Sensitivity 90 dB (1 W / 1 m)
Nominal Impedance 8 ohms
Minimum Impedance 3.4 ohms
Rated Power 110 W
Peak Power 770 W
Placement Floorstanding
Dimensions (H x W x D) 110 x 25 x 35 cm
Weight 24 kg
Finish Options All black, white lacquered, black lacquered
What’s in the Box
  • Cabasse JAVA MC40
