Burson Audio
Burson Audio Super Charger - Clearance
Regular price $69.99
Sale price $69.99 Regular price $284.00
Save 75%
1 of 9
Burson Audio
On saleClearance
Save 75%
Licence to thrill.
There are no gimmicks here. We did not invent new elements nor space-tech. And submarines certainly do not use it to lower their noise floor. Instead, it is based on nearly two decades of experience building power supplies for audio, then assembled with the best parts we can find. The resulting improvement is instantly audible and across the entire audio spectrum.
Super Charge your Burson and take its performance to an even higher level.  It is the final icing on the cake!
Lower Noise = More Details
Off-the-shelf power units have an operating frequency that’s just above the human hearing threshold. In contrast, the Burson Super Charger works at an even higher frequency, resulting in a much lower DC noise—instantly improving the final noise to signal ratio which allows a deeper dive into micro-details.
Higher Frequency = More Dynamics
The Burson Super Charger doubles the charging frequency to power capacitors inside the audio amplifier. The resulting sound is more impactful with a bigger and deeper soundstage.
Burson Product Compatibility
Burson Designs Super Charger 3A Super Charger 5A
Conductor 3XR Yes Yes
Conductor 3R Yes Yes
Timekeeper 3Ri No No
Conductor 3XP Yes Yes
Conductor 3P Yes Yes
Composer 3XP Yes Yes
Soloist 3X GT No Yes
Soloist 3XP Yes Yes
Playmate 2 Yes Yes
Funk Yes Yes
Compatibility with Other Products:
To find out its compatibility with other products, please follow the steps below:
  • Is your current PSU 24Volt with the same amp or less? (eg 3A or less)
  • Does it have a 2.5mm DC barrel plug?
  • Does it have a centre positive polarity?
If the answer is YES to all three, then our Super Charger 3A is compatible.
General Spec
Dimension: 85 x 75 x 28mm
Weight: 240g
Cable Length: 1.8 Meter
Input Connector Type: US, AUS, EU, UK
Ouput Connector Type: 2.5mm Barrel Plug (Center Positive)
Electrical Spec
Input Range: 100 - 240V AC
Output 24V AC @ 3A
Noise Floor: <1uV
