Burson Audio
Burson Audio Soloist 3x Grand Tourer - Open Box
Regular price $1,699
Sale price $1,699 Regular price $2,499.00
1 of 7
Burson Audio
All Open-Box Burson Audio Soloist 3x Grand Tourers are tested, inspected and cleaned and sold in like-new condition.
AN EPIC GRAND TOURER
The Soloist GT is an idealist. From its resonance-free enclosure to its tuned-up power supplies. From its symmetrical layout to its multi-layered circuitry board, We are over-engineering every element of this Grand Tourer to create an epic classic.
It fulfils the wishes of those who love the Soloist lineage and redefines the limits of performance.
SYMMETRICAL THROUGH AND THROUGH
You can’t judge a book by its cover, but you can judge circuitry by its layout. Symmetrical dual-mono is beautiful and achieves the highest possible audio performance.
Under the bonnet, the GT has two independently pod mono amps in mirrored symmetry. The resulting pitch-black soundstage and crisp details are breathtaking!
POWERING THE GT
The thumping heart of the Soloist GT is 5 sets of Burson Max Current Power Supplies. We are pushing these MCPS to the limits of their potential. So much so that they need active cooling.
The result is a pure Class-A, 10Wpc dream machine.
SYMMETRICAL AUDIO PATHS
The V6 Vivid discrete opamps are wildly regarded as the best globally and used in countless recording studios.
The GT uses three V6 Vivid opamps per channel, achieving incredible transparency. However, it still plays to your preference by allowing opamps to change, enabling you to create your own listening experience.
The typical stereo volume control creates lots of cross channel interference. Industry aristocrats such as Pass Lab and AVM use the MUSES72320 volume control to reduce such distortion in their flagships preamps.
The Soloist GT goes further by using one MUSES72320 + V6 Vivid discrete buffer volume control per channel, eliminating any chances of cross channel interference.
HEADPHONE CROSSFEED
Live music and loudspeaker sound arrive at your head mixed. It gives you a sense of positioning. Most recording engineers also work under the assumption that their tracks will be playing through stereo speakers, not headphones.
Some headphone listeners use software to create that crossfeed, but such DSP often create other distortions.
The Soloist GT has three levels of hardware-based crossfeed emulation. So you can listen to your favourite track, exactly the way you like it!
GT COOL.
Our Burson Cool Case is already the most oversized heat sink on any headphone amp. Still, we adopted active cooling for the GT.
With every component operating in a predetermined temperature range, independent of the environment, active cooling gives us the freedom to push the GT to its performance limit.
To eliminate wind noise, we designed a new enclosure to enhance stiffness and reduce resonance. Combining this resonance-free enclosure with the quietest fan money can buy from Noctua in Austria, wind noise sits below 25dBA. In comparison, an empty recording studio has over 30dBA of ambient noise. So, the GT is quieter than the background ambience of your music.
SPEAKER CENTERING
Who can afford a fully symmetrical, sound-treated home auditorium? For everyone else, it is so typical to have a door or window near one speaker and a bookshelf near the other. These elements distort the sound stage.
With one MUSES+V6 Vivid volume controller per channel, you can adjust the volume of each stereo speaker separately. Bring you closer to that perfect sound stage previously reserved for the fortunate few!
HEAD+SUB MODE. SAY WHAT!?
We feel sound as much as we hear sound. Before the invention of headphones, music listening has always been a full-body experience. It’s not just what your ears can hear but all the energy that your body feels that move the soul.
Headphone listening goes to a new level with a carefully matched and placed subwoofer. The GT enables this experience with its Head+Sub mode.
REV IT UP!
The Soloist 3X GT is a drive for perfection. Headphones may change, and digital formats come and go, but this analogue performer is timeless.
It let us hear and feel more. So fire up the GT, and ride down memory lane. Revisit moments when life changed tracks and the songs enriching the journey.
Measurement
  • Input impedance: 35 KOhms
  • Frequency response: ± 1 dB 0 – 48Khz
  • THD: <0.0015%
  • Output impedance (Headphone Amp): 0.5 Ohm
  • Output impedance (Pre Out ): 25 Ohm
  • Inputs: 2 x XLR
    2 x RCA
    1 x Mic Bypass
  • Outputs: 1 x XLR Preamp
    1 x RCA Preamp
    1 x RCA Subwoofer Output
    1 x XLR Headphone Jack
    1 X SE Headphone Jack
General
  • Weight: app. 5 kg (12 lb)
  • Dimensions: 255mm x 270mm x 70mm
Power
  • 16 ohm: Unbalanced = 5w
    Balanced = 10w
  • 32 ohm: Unbalanced = 4w
    Balanced = 8w
  • 100 ohm: Unbalanced = 1.9w
    Balanced = 3.8w
  • 300 ohm: Unblanced = 650mW
    Balanced = 1.3w
  • 600 ohm: Unbalanced = 320mW
    Balanced = 640mW
In The Box
  • Burson Soloist Unit
  • IC Opamps for warranty diagnostic use.
  • Remote Control
  • Hex key
  • Power Supply
