Burson Audio Funk Amplifier - Open Box
Amplifier type
Portability
Burson Audio
Funk the Rule!
Hi-Fi companies are spoiling headphone enthusiasts with nearly endless amplifiers. So why are they neglecting near-field audiophiles, listening to their speakers in small studios or from their desktops?
Near-field-audiophiles often settle for inferior Class-D amps, which are also typical inside active speakers. The alternative is rack size Class-AB amps that break the aesthetic of any near field systems.
This neglect is due to the rule between size and performance. It was impossible to make a speaker amp that looks great next to your iMac yet performs at the audiophile level.
Funk breaks that rule!
Funking Class-AB
Traditional Class-AB reigns supreme for speaker amps and the Funk is a true-blue 45Watts per channel Class-AB. Powered by our proprietary Max Current Power Supply, it resets your perception of rhythm through power, precision and micro-details. It makes most conventional amplifiers, even the ones with twice the declared power, sound slow and dopey.
Funk is more Fun!
Fully discrete, Class-A, 3Wpc. Funk is also a vastly improved Burson Fun, which won Product-of-Year on Headfonia and loved by head-Fiers since 2017. It has higher resolution and power and infinitely sexier looking. IEM, no worries. Big cans, no sweat!
Small and For All
This insane size vs performance ratio is made possible by our proprietary Max Current Power Supply technology, which removed the need for heavy transformers and oversized power caps. It delivers instant and clean power directly to the output transistors.
Funk it your way
Your headphones are very different from your speakers. So why should your amp treat them the same?
With two separate signal paths and each facilitating opamp rolling, you can tune the Funk to match your headphones and speakers separately.
Funk and Games
Gaming headset compatibility, ticked.
Soundcard connectivity, ticked.
Movie night, game night, Funk it any way you like.
Funk is Cool
Touch and feel the Funk then our competition. The difference will be striking. Precision machined, this beautiful aluminium enclosure is also a unified heat-sink, keeping the Class-A headphone amp and Class-AB speaker amp running cool while looking hot.
