Burson Audio
Burson Audio Conductor 3 GT
Amplifier type
Portability
Elevate Your Audiophile Experience with Burson Audio Conductor 3 GT
Experience unparalleled audio refinement and versatility with the Burson Audio Conductor 3 Grand Tourer (GT) - a flagship DAC, head-amp, and preamp all rolled into one extraordinary device. Designed to transcend the boundaries of traditional audio equipment, the Conductor 3 GT takes Burson's signature sound to new heights with a meticulously engineered output stage, bespoke components, and groundbreaking features.
Unleash the Full Potential of Your Audio
The Conductor 3 GT goes beyond conventional DACs, presenting a realm where sound is truly individualized. Unlike off-the-shelf DACs that yield generic sonic results, the Conductor 3 GT takes a revolutionary approach. It introduces a specially tailored output stage that optimizes the wide bandwidth of the Vivid op-amps. Combined with the proprietary Max Current Power Supply, the Conductor 3 GT delivers remarkable sonic depth and nuance, revealing details in every musical note like never before.
Unveil Sonic Artistry with Advanced Digital Interfaces
With an unwavering commitment to sonic excellence, Burson equips the Conductor 3 GT with advanced digital interfaces. From its state-of-the-art XMOS USB receiver to the Qualcomm Bluetooth module, every detail has been meticulously designed for unparalleled accuracy. Its customized Thesycon driver ensures unparalleled processing power, enabling seamless streaming of DSD512 and 32bit/768khz audio. The Bluetooth 5.0 receiver featuring aptX HD audio and LDAC codec takes wireless audio playback to unprecedented levels of quality and convenience.
Precision Control Meets Luxurious Design
The Conductor 3 GT offers a serene and intuitive user experience through its all-new OLED screen and interface program. Its solid aluminum machined knob exemplifies precision and luxury, allowing you to effortlessly navigate through settings and preferences.
Unprecedented Power and Cooling
At the heart of the Conductor 3 GT, five sets of Burson Max Current Power Supplies provide the pulsating power required for its exceptional performance. This innovation pushes the limits of potential, consuming 90W even at idle, necessitating active cooling. Burson's innovative approach ensures that the pursuit of purity is maintained even while generating up to 10 Watts, allowing the sound to remain uncompromised.
The Ultimate All-In-One for Discerning Audiophiles
The Conductor 3 GT isn't just a piece of audio equipment; it's a sonic masterpiece designed to harmoniously coexist with your musical journey. Its compatibility with Roon's streaming and music management platform further solidifies its position as an essential component for audiophiles. Designed to seamlessly integrate with any Roon Ready audio streamers, the Conductor 3 GT enhances your audio experience to an extraordinary level.
- Input impedance: 40 KOhms
- Frequency response: ± 1 dB 0 – 58Khz
- THD: <0.0015%
- Output impedance (Headphone Amp): 0.5 Ohm
- Output impedance (Pre Out / DAC Out): 1 Ohm / 25 Ohm
Conductor 3 GT Info
- Inputs: 2 x RCA line-level input, USB, Optical Toslink, BlueTooth 5.0, microphone
- Outputs: 2 x RCA Pre Amp/Line-Level DAC Out, 1XSubwoofer Pre Amp, 1 x 6.3mm & 1 x XLR Headphone Jack
DAC Specifications
- Channel Separation: 142 dB @ 1KHz, 135 dB @ 20KHz
- THD+N: 0.0005% @ 1KHz, 0dBFS
- COAX & Toslink / SPDIF: up to 24bit 192K
- Native DSD: Native DSD 64 / 128 / 256 / 512
Bluetooth Input
- Bluetooth 5.0 aptX HD (Qualcomm CSR8675)
Impedance (Headphone Jack) Power, Signal to Noise Ratio, Separation
- 16 Ohm: 10W, 112dB
- 32 Ohm: 8W, 110dB, 99%
- 100 Ohm: 3.8W, 111dB, 99%
- 150 Ohm: 1.3W, 110dB, 99%
- 300 Ohm: 640mW, 109dB, 99.50%
In the Box
- Burson Conductor Unit
- IC Opamps for warranty diagnostic use
- USB-C to USB-C Cable
- Remote Control
- Hex key
- Power Supply
- Burson Conductor 3GT User Manual
