Bowers & Wilkins
Bowers & Wilkins PI7 True Wireless Noise Cancelling In-Ear Headphones
Cup style
Wearing style
Driver type
Dynamic, Balanced Armature
Wireless
Smart playback, high-quality listening, and clearer speaking without wires are the hallmarks of the Bowers & Wilkins PI7 True Wireless In-Ear Headphones with Active Noise Cancellation.
Utilizing Bluetooth 5.0, your favorite music, podcasts, and other audio content is streamed and played back via two drivers per earbud for a richer soundstage. Each have a dynamic 9.2mm driver for mids and bass, and a balanced armature tweeter for the highs. Both also sport four dedicated amplifiers and 24-bit/48 kHz resolution. To further improve wireless quality, PI7 supports various aptX codecs (Standard, LL, HD & Adaptive). A 24-bit connection helps to ensure this vibrant audio is properly synced between the earbuds.
Your listening experience is further improved by what you don't hear, as each earbud has a microphone and adaptive active noise cancellation technology. This monitors ambient noise levels, adjusting to filter out distracting noise. With the PI7, audio clarity goes both ways. You can use the PI7 earbuds to make hands-free calls and each earbud has two cVc mics to better pick up your voice when speaking. All of this and more can be done for up to 4 hours on a full charge, with an additional 16 hours of charging power available in the included wireless charging case.
Charging Case with Audio Retransmission
When the case is not in use, you can utilize it for audio retransmission from a wired source. Simply plug in the included USB Type-C to 3.5mm audio cable into the case's USB Type-C port, and the other end into any compatible audio device. Play that device and the audio is sent into the case and streamed to your PI7 earbuds. It's an ideal solution for enjoying true wireless freedom on airplanes or with older devices.
Ambient Pass-Through
Wear Sense
Additional Features
- Dedicated external DSP
- Integrated multi-touch button
- Supports delivering voice commands to mobile digital assistants
- Pair to multiple devices
- IP54-rated water resistance
- 15-minute quick charge gives 2 hours of Bluetooth playback
True 24-bit connection with aptX™ Adaptive
Hear your favourite music and movies as they were meant to be heard, thanks to a true 24-bit connection between left and right earbuds for superior sound quality plus high-resolution wireless audio that adjust dynamically to optimise performance.
Hear music and movies as the artist intended
Small, yet powerful, two-way drive units in each earbud work just like high-performance speakers, creating rich, immersive sound - from deep and powerful bass to expressive and detailed high notes, and everything in between.
Adaptive active noise-cancellation
Advanced active noise-cancellation monitors noise and adapts to your surroundings, so nothing gets in the way of the music you love.
Wireless audio retransmission technology
A transformative Smartcase that also functions as an audio retransmission system, connecting directly to external audio sources such as in-flight entertainment systems.
