AudioQuest
AudioQuest PowerQuest 303 Power Conditioner
The AudioQuest PowerQuest 303 is the ultimate solution for ensuring clean, reliable power for your audio equipment. Designed with precision and performance in mind, this high-performance power conditioner offers 12 AC outlets, featuring 4 High-Current outlets optimized for amplifiers and 8 Linear-Filtered outlets tailored for source components. Its advanced technologies protect your valuable gear from the detrimental effects of dirty power, ensuring an enhanced audio experience with minimal interference.
Advanced Linear Noise Dissipation Technology
AudioQuest’s PowerQuest 303 employs cutting-edge linear noise-dissipation technology, which eliminates electromagnetic and radio-frequency interference that can degrade your sound quality. With more than -22dB of noise attenuation, this conditioner effectively filters differential-mode noise between 30kHz and 1GHz. Paired with the included PQ-415 noise-dissipating cable, featuring semi-solid concentric long-grain copper conductors and a flat-to-wall plug design, the PowerQuest 303 ensures your audio system operates in a pristine power environment.
Non-Sacrificial Surge Protection for Maximum Safety
Protect your gear with confidence, thanks to the PowerQuest 303’s non-sacrificial surge protection. Unlike traditional surge protectors that fail after a single event, the PowerQuest 303 is built to handle multiple transient power surges without sustaining damage. Whether it's micro-spike protection for short, fast blasts or catastrophic surge protection against lightning strikes, this power conditioner safeguards your equipment while maintaining its own functionality.
Automatic Shutdown for Extreme Voltage Events
In the event of a catastrophic power surge, the PowerQuest 303’s extreme-voltage automatic shutdown feature activates at 140VAC, opening the main power relay within 0.25 seconds to protect your gear. Once the incoming power stabilizes, the system automatically resets itself, ensuring your equipment remains secure even in the most unpredictable environments. This feature offers unmatched peace of mind for audiophiles and professionals alike.
Optimized Outlets and USB Charging Ports
With 12 total outlets, including 8 optimized for source components and 4 high-current outlets for amplifiers and power-hungry devices, the PowerQuest 303 ensures tailored performance for all your gear. Additionally, the inclusion of USB-A and USB-C charging ports simplifies powering your portable devices, making the PowerQuest 303 as versatile as it is powerful. Whether you’re charging your smartphone or running a full audio rig, this power conditioner has you covered.
Built for Convenience and Versatility
Designed for both desktop and rackmount use, the PowerQuest 303 includes 2RU rack ears for seamless integration into professional setups. Its compact 2U form factor, robust build quality, and sleek design make it a practical addition to any audio or home theater system. With an easy-to-use design and comprehensive protection features, the PowerQuest 303 delivers clean power and reliable performance wherever you need it.
Key Features of the AudioQuest PowerQuest 303
- Noise Dissipation: Advanced linear filtering with over -22dB noise attenuation.
- Surge Protection: Non-sacrificial technology for multiple transient surges.
- Voltage Shutdown: Automatic protection at 140VAC with quick reset capabilities.
- Optimized Outlets: 12 AC outlets tailored for source and high-current devices.
- USB Ports: High-speed USB-A and USB-C for charging convenience.
- Durable Build: 2U rackmount form factor with rack ears included.
Specification | Details |
Type | Power Conditioner |
Format | 2U Rackmount, Desktop |
Number of Outlets | 12 x Rear (4 High-Current, 8 Linear-Filtered) |
Output Current | 15A |
Filtering | Linear Filtering |
Overload Protection | Extreme-Voltage Shutdown |
Rackmountable | Yes, 2U |
Power Source | PQ-415 IEC power cable |
Height | 3.4" |
Width | 17" |
Depth | 13.4" |
Weight | 10.2 lbs. |
Manufacturer Part Number | PQ303NA |
Invest in Clean Power for Superior Performance
Dirty power can compromise your gear’s performance and longevity. With the AudioQuest PowerQuest 303, you can ensure your audio components are protected, optimized, and delivering their best performance. Perfect for audiophiles, home theater enthusiasts, and professionals, this power conditioner is a reliable and versatile solution for clean and consistent power.
