AudioQuest
AudioQuest Golden Gate 3.5mm - RCA Analog Interconnect
Regular price $109.95
Sale price $109.95 Regular price $109.95
 More payment options
NaN of -Infinity
AudioQuest
In stock and Shipping Now Order within 2 days 8 hours to have it shipped Monday.
Members earn 110 points on this purchase.
The AudioQuest Golden Gate 3.5mm to RCA Cable (4.9') is designed to reduce distortion in your signal. To achieve this the audio cable utilizes solid perfect-surface copper conductors in a double-balanced asymmetrical geometry with foamed-polyethylene insulation, a metal-layer noise dissipation system, and cold-welded gold-plated RCA plugs.
The solid perfect-surface copper conductors have less oxides, less impurities, and less grain boundaries than industry standard oxygen-free high conductivity copper, which reduces the amount of magnetic and electrical interference within the cable. The double-balanced asymmetrical geometry lowers the impedance on the ground plane and improves the dynamic response of the signal. The foamed-polyethylene insulation creates an air insulator around the conductors which significantly reduces the absorption of energy and presence of distortion in the cable. The metal-layer noise-dissipation system blocks RF interference from entering the ground plane of the cable. The use of cold-weld connections ensures that the joints between the cable and hardware have a reduced influence on signal clarity. The gold-plated RCA plugs will not oxidize, tarnish, or corrode the same way other metals can. All of these features combine to provide you with an audio cable with reduced distortion.
Solid Perfect-Surface Copper Conductors
The solid perfect-surface copper conductors have less oxides, less impurities, and less grain boundaries than industry standard oxygen-free high conductivity copper and therefore causes less magnetic and electrical interference within the cable
Foamed-Polyethylene Insulation
Metal-Layer Noise-Dissipation System (NDS)
Double-Balanced Asymmetrical Geometry
The double-balanced asymmetrical geometry of the cable lowers the impedance on the ground plane and improves the dynamic response of the signal
Cold-Weld
Unlike traditional hot solder joints, the cable uses high pressure cold-weld connections
Gold-Plated RCA
