AudioQuest Forest USB A to USB B Digital Interconnect
365-day returns
AudioQuest
Features :
- Solid 0.5% Silver Conductors
- Solid High-Density Polyethylene Insulation
- Gold-Plated Terminations
- Universal Serial Bus Device Class Definition for Audio Devices
Solid 0.5% Silver Conductors :
Solid conductors eliminate strand-interaction distortion and reduce jitter. Solid silver-plated copper conductors are excellent for very high-frequency applications, like Ethernet audio. These signals, being such a high frequency travel almost exclusively on the surface of the conductor. As the surface is made of high-purity silver, the performance is very close to that of a solid silver cable, but priced much closer to solid copper cable. This is an incredibly cost effective way of manufacturing very high quality USB cables.
Solid High-Density Polyethylene Insulation :
Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then later released as distortion. Solid High-Density Polyethylene Insulation ensures critical signal-pair geometry while minimizing insulation-induced phase distortion.
Gold-Plated Terminations :
Precision gold-plated plugs are carefully attached with the very best solder. Through choice of flux and metallurgy, AQ solder has been optimized to make a low-distortion connection. The difference you hear between solders is a result of connection quality. AQ solder does not have a high silver content because the more silver there is in solder, the more difficult it is to make a good connection.
Universal Serial Bus Device Class Definition for Audio Devices :
USB (Universal Serial BUS) was established by a stalwart group of companies such as Intel, Hewlett-Packard, and Microsoft (just to name a few) in order to give the personal computing world a truly universal standard and means to connect devices such as hard drives, printers, cameras, and, more importantly to us, audio components. Included in the original description are protocols for the pristine transfer of audio over USB. Great care and sensitivity went into this. Consequently, a computer connected to a USB-enabled digital-to-analog converter can outperform the best compact disc players available today. AudioQuest is committed to contributing products that honor USB's ability to deliver state-of-the-art performance on this new and wonderful frontier.
*Headphones.com is very pleased to announce that you have even more options to pay for your AudioQuest USB cables! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
