Audeze
Audeze Maxwell 2 Wireless Gaming Headphones
Regular price $329
Sale price $329 Regular price $329.00
1 of 5
Audeze
Regular price $329
Reference sound meets real gaming endurance
Wireless, Wired
The Audeze Maxwell 2 takes everything that made the original Maxwell a standout and pushes it further. With upgraded planar magnetic drivers, improved comfort, smarter microphone processing, and new customization options, Maxwell 2 delivers reference-level audio performance in a wireless gaming headset built for serious play.
Gaming, Uncompromised
Maxwell 2 is designed for players who want top-tier audio without sacrificing wireless convenience. The new 90mm planar magnetic drivers deliver massive scale, pinpoint imaging, and studio-grade clarity that makes footsteps, reloads, and environmental cues feel lifelike and precise.
Planar Magnetic Power
At the heart of Maxwell 2 are Audeze’s largest gaming planar drivers ever. The 90mm transducers use Fluxor magnet arrays, Fazor phase management, Uniforce diaphragms, and SLAM acoustic tuning to produce deep, controlled bass, clean mids, and extended treble without distortion or fatigue.
Ultra Low Latency Wireless
Maxwell 2 delivers lag-free, high resolution wireless audio up to 24-bit/96kHz using its USB-C wireless dongle. Whether you are gaming competitively or streaming media, audio stays perfectly in sync with what you see on screen.
Comfort, Reimagined
Built for long sessions, Maxwell 2 features a redesigned wide ventilated head strap and upgraded ear pads with more internal space. The result is better weight distribution, improved airflow, and all-day comfort for a wider range of head shapes and sizes.
AI Powered Microphones
Advanced FILTER AI noise removal ensures your voice stays clear and natural on chat and stream. Background noise is intelligently removed at the push of a button, while the detachable hypercardioid boom mic delivers focused voice pickup when precision matters most.
Versatile Connectivity
Maxwell 2 works seamlessly across platforms with USB-C wireless, USB-C wired audio, Bluetooth, and 3.5mm analog support. Bluetooth includes support for Auracast, LE Audio, LDAC, AAC, and multipoint, making it easy to switch between gaming, music, and calls.
The New Audeze App
A completely redesigned Audeze app gives you fast access to EQ, mic controls, sidetone, and device settings. Available on Windows, macOS, iOS, and Android, the app offers a clean, modern interface built for quick adjustments.
ReSkin Customization
Maxwell 2 introduces the new ReSkin system, allowing you to swap magnetic side plates to customize the look of your headset. Limited edition designs and collaborations are planned, with more options coming soon.
Audeze Maxwell 2 headphones versatile connectivity options
Platform Compatibility
  • PC and Mac with ultra-low latency wireless, USB-C audio, 3.5mm analog, Dolby Atmos, game and chat mix
  • Xbox with ultra-low latency wireless, 3.5mm analog, Dolby Atmos, game and chat mix
  • PlayStation with ultra-low latency wireless, USB-C audio, 3.5mm analog, Tempest 3D
  • Switch 2 with ultra-low latency wireless, Bluetooth audio, USB-C audio, 3.5mm analog
  • iOS and Android with Bluetooth, USB-C audio, 3.5mm analog, and app support
In the Box
  • Maxwell 2 headset
  • Detachable boom microphone with pop filter
  • USB-C wireless dongle
  • USB-C to USB-C cable (1.5m)
  • USB-C to USB-A adapter cable (0.3m)
  • 3.5mm TRRS analog cable (1.2m)
Design Over-ear, closed-back
Driver Type Planar Magnetic
Driver Size 90 mm
Frequency Response 10Hz to 50kHz
Maximum SPL Greater than 115dB
Total Harmonic Distortion Less than 0.1 percent at 100dB
Weight 560g
Battery Life Over 80 hours wireless playback
Fast Charging 20 minutes for up to 24 hours playback
Wireless USB-C ultra-low latency, Bluetooth 5.3
Bluetooth Codecs Auracast, LE Audio, LC3, LC3plus, LDAC, AAC, SBC
Wired Connections USB-C digital, 3.5mm TRRS analog
Microphones Detachable hypercardioid boom mic, internal beamforming mic
