64 Audio
64 Audio U6t In-Ear Headphones - Open Box - Clearance
Regular price $699
Sale price $699 Regular price $1,299.00
1 of 7
64 Audio
Clearance
Regular price $699
Balanced Armature
Open-box items in C condition are open box items that are not in like-new condition. They may show signs of wear, have packaging that is imperfect and be missing accessories. Clearance items are sold as is without a warranty guarantee and no returns.
Six Driver Universal In-Ear Monitor
64 Audio U6t In-Ear Monitor Headphones | Headphones.com
64 Audio’s most popular CIEM now available in a universal form. Drawing from the sonic palette of U12t, U6t is our most affordable audiophile monitor to date. Boasting the same groundbreaking technology as our flagship IEMs in our ergonomic aluminum shell to make it more accessible than ever.
While looking towards U12t for sonic inspiration, the U18s influenced the new dark grey matte shell finish as well as its newly redesigned packaging and proprietary cable. The understated shell design and classic black faceplate reflect what you can expect from the new generation of 64 Audio’s audiophile products.
SOUND
In standard 64 Audio fashion, U6t is a balanced natural sounding earphone, slightly set apart from our other UIEM models by offering a softer presentation of a mix. Beautiful upper-mid imaging, realistically presenting instruments like guitars and piano as well as breathing life into saturated mid-bass mixes, especially when vocal focused. Using the various included apex modules and ear-tips allows the listener to further customize the sound of the U6t based on the needs of the music.
64 Audio 6 Balanced Armature Driver In-Ear Monitor Headphones
TECHNOLOGY
Exclusive technologies that challenge traditional in-ear monitor designs to give you the absolute best listening experience.
A tubeless design that reduces resonance for a transparent and lifelike sound signature
The tia system is comprised of three major elements: open balanced armature tia drivers, the tia single-bore design, and tia acoustic chambers. The U12t features two major elements of the tia system: the tia driver and the tia single-bore design.
Tia Driver
An open balanced armature speaker design for realistic resolution and transparency. By opening a balanced armature, the diaphragm becomes fully unobstructed, reducing resonance in the IEM and allowing sound to travel more naturally to the ear.
Tia Single Bore
A huge advancement in eliminating unwanted tube resonance. The large bore itself serves as a sound-shaping chamber and aids the tia high driver in delivering a linear and coherent frequency response. The short sound path provides remarkable high-frequency extension and smoothness. The large single bore also allows for easier maintenance
64 Audio U6t $1299 in-ear headphones made in the USA | Headphones.com
Apex
Only from 64 Audio, apex alleviates listener fatigue by releasing air pressure sealed in the ear canal. This venting enables musicians and music enthusiasts to listen more comfortably for longer.
Apex, or Air Pressure Exchange, is a pneumatically interactive vent that releases air pressure from a sealed ear canal. Apex comes in two variations, m15 (-15dB) and m20 (-20dB).
Alleviate Listener Fatigue
When you seal a miniature speaker in an ear canal, the air inside becomes trapped. Apex relieves this air pressure, allowing the eardrum to move naturally, so you can comfortably listen longer.
Extend The Soundstage
Freely moving air extends the soundstage and provides a more natural listening experience. It also preserves bass frequencies and helps the listener distinguish individual instruments.
Hear Your Audience
Custom in-ear monitors provide amazing isolation and help you hear your mix more clearly and at lower volumes than a wedge monitor or earbuds. Apex lowers decibel levels while preserving the clarity of the sounds around you, so artists on stage can connect with their audience while protecting their hearing.
LID
Enables a consistent, reliable sound regardless of audio source.
LID, or Linear Impedance Design, enables a consistent, reliable sound regardless of what source. This proprietary circuit corrects the non-linear impedances of the drivers, restoring proper interaction with the source and preserving the desired sound signature.
Whether you're a musician plugging into a variety of gear at different gigs or studios, or an audiophile listening from low-impedance sources, LID ensures your IEMs are delivering the desired sound signature consistently.
And like all our IEMs, this model can be used with a wide range of personal audio devices as well as all hard-wired and wireless monitor systems.
64 Audio U6t In-Ear Headphones with new Premium Cable | Headphones.com
SPECIFICATIONS
Driver Type/Count
Six precision balanced armature drivers
Driver Configuration
1 tia high, 1 hi-mid, 2 mid, 2 low
Frequency Response
10Hz – 20kHz
Sensitivity
108 dB/mW
Impedance
10Ω Nominal
Crossover
Integrated 4-way passive crossover
Isolation
-20dB with m20 apex module
Exclusive New Premium Cable
  • 0.23 Ohms Total Impedance
  • 7 x 7 x 4 Multi-Twist
  • Silver Plated OCC Copper Wire
  • 26 Awg
IN THE BOX
  • U6t Universal In-Ear Monitors
  • TrueFidelity Eartips (S,M,L)
  • Silicone Eartips (S,M,L)
  • SpinFit Eartips (S,M,L)
  • Black Premium Cable
  • m20 apex Modules
  • m15 apex Modules
  • Round Sticker
