64 Audio
64 Audio TWELVE Ti In-Ear Headphones
Regular price $2,499
Sale price $2,499 Regular price $2,499.00
1 of 11
64 Audio
Balanced Armature
TWELVE TI has completely sold through and no more stock will be coming in. You can get the 64 Audio U12t here.
The 64 Audio TWELVE Ti is a special edition of one of the most celebrated universal in-ear monitors ever made. Built on the same platform that made the U12t a long-running reference point for audiophiles, engineers, and musicians, the TWELVE Ti takes that proven formula and gives it a more premium execution through titanium shells, titanium faceplates, and an exclusive titanium m20 apex module.
That matters because the U12t was already the kind of IEM people bought intending it to be their last stop. TWELVE Ti keeps the same highly regarded sound signature and technical performance, then wraps it in a more distinctive and more enduring design. If you love the U12t but want the most premium expression of it, this is exactly that.
TWELVE Ti vs U12t
The easiest way to understand the TWELVE Ti is to think of it as the U12t in its most elevated form. The core tuning, driver configuration, and patented 64 Audio technologies remain intact, which is exactly why the TWELVE Ti makes sense. The U12t did not need to be reinvented. It needed to be celebrated.
What changes here is the execution. TWELVE Ti replaces the standard aluminum shell with a full titanium build, adds matching titanium faceplates, includes an exclusive titanium m20 apex module, and comes with specially made shielded cables that complete the look and feel of the special edition. The result is a more premium, more distinctive version of an IEM that was already considered a benchmark.
TWELVE Ti delivers the same kind of sound that made the U12t such a fixture in high-end personal audio: immersive imaging, articulate highs, strong detail retrieval, and a low end that stays warm, engaging, and controlled. It is the kind of tuning that works because it balances technical performance with long-term listenability. You get reference-level detail, but not at the expense of musicality.
This is one of the reasons the U12t has stayed relevant for so long. It does not force you to choose between precision and enjoyment. TWELVE Ti keeps that same appeal intact, making it just as compelling for critical listening as it is for simply getting lost in music.
Titanium Build
Each TWELVE Ti shell is machined from a solid piece of titanium and finished in a matte natural color. Compared with the standard U12t, this gives the special edition a more distinctive visual identity and a more premium material story without changing what listeners already love about the fit and sound. It feels like a flagship version of a flagship.
Titanium also suits the product aesthetically. The shells, faceplates, and dedicated m20 apex module all follow the same design language, giving the TWELVE Ti a much more cohesive look than a simple cosmetic refresh. It feels intentional from every angle.
Shielded Cable
TWELVE Ti includes a specially crafted shielded cable designed to match the titanium aesthetic and the premium nature of the IEM itself. The four-core cross-braided design uses silver-plated, single-crystal copper and is rated at a very low 0.29 ohms total impedance for clean signal transmission and strong compatibility across a wide range of sources.
Both a 3.5 mm single-ended cable and a 4.4 mm balanced cable are included in the box, so you can move between portable sources, desktop gear, and balanced outputs without needing to buy anything extra.
64 Audio Technology
tia, short for Tubeless In-Ear Audio, is 64 Audio’s patented approach to reducing unwanted resonance and distortion. In the TWELVE Ti, this includes the tia driver and tia single-bore design, helping preserve the clean, open, and transparent presentation the U12t family is known for.
apex, or Air Pressure Exchange, is 64 Audio’s pressure-relief system. By venting pressure in the sealed ear canal while retaining useful isolation, apex helps reduce listening fatigue and contributes to a more spacious and natural presentation. TWELVE Ti supports four apex module options: mX, m12, m15, and m20, with the titanium special edition including an exclusive titanium m20 module.
LID, or Linear Impedance Design, helps keep the frequency response more consistent across different source devices. That means whether you are listening from a phone, dongle DAC, DAP, or desktop amplifier, TWELVE Ti is designed to preserve its intended tuning more reliably than many other multi-driver IEMs.
Key Features
  • Special edition version of the legendary 64 Audio U12t
  • Full titanium shells and faceplates in a matte natural finish
  • Exclusive titanium m20 apex module
  • Same highly regarded U12t sound signature and 12-driver platform
  • 1 tia high driver, 1 high-mid driver, 6 mid drivers, and 4 low drivers
  • tia driver and tia single-bore design for reduced resonance and distortion
  • apex pressure-relief system with mX, m12, m15, and m20 module support
  • LID for more consistent tuning across different source devices
  • Specially made shielded cable with silver-plated UP-OCC copper conductors
  • Includes both 3.5 mm single-ended and 4.4 mm balanced shielded cables
  • 0.78 mm 2-pin connector system
  • Designed, assembled, and quality controlled in the United States
Technical Specs
Product Type Universal in-ear monitor
Color Titanium
Shell Material Tc4 titanium shell and faceplate
Faceplate Chip Electroformed stainless steel
Driver Configuration 1 tia high driver, 1 high-mid driver, 6 mid drivers, 4 low drivers
Frequency Response 10 Hz to 20 kHz
Sensitivity 108 dB/mW @ 1 kHz
Impedance 12.6 Ω
Apex Isolation -10 dB to -20 dB
Cable Connector 0.78 mm 2-pin
Cable Construction 24 AWG 4-core litz, 99 strands per core, silver-plated UP-OCC copper
Cable Impedance 0.29 Ω total impedance
What’s in the Box
  • 64 Audio TWELVE Ti universal in-ear monitors
  • Carry case
  • TrueFidelity foam ear tips (S, M, L)
  • SpinFit silicone ear tips (S, M, L)
  • Silicone ear tips (S, M, L)
  • 3.5 mm shielded cable
  • 4.4 mm balanced shielded cable
  • Shirt clip
  • Cleaning tool
  • Cleaning cloth
  • Round sticker
  • apex modules: m20, m15, m12, mX
