TRUTHEAR
TRUTHEAR x Crinacle ZERO:Red In-Ear Headphones
Precision Crafted Sound
Wearing style
Driver type
Portability
Discover the fusion of technology and artistry with the TRUTHEAR x Crinacle ZERO:Red In-Ear Headphones. These earphones aren't just about superior sound; they represent a dedication to sonic excellence and innovative engineering.
Optimized Processing Technology
TRUTHEAR emphasizes not only on stellar acoustic performance but also on the refinement of processing technology. The ZERO:RED's internal structure maintains a sophisticated design, ensuring that every component, from the front cavity to the decorative panel, is meticulously placed and sealed for optimal sound delivery.
Meticulous Design and Durability
Through advanced 3D printing technology and careful hand-finishing, the ZERO:RED achieves a sleek, natural curvature. This precise construction process results in a faceplate that's not only stunning but also robust, guaranteeing that these in-ear headphones withstand the test of time and use.
Accurate Hybrid Double Frequency Division
Leveraging high-precision DLP-3D printing, the ZERO:RED creates a unique acoustic nozzle structure that, combined with precise frequency division, allows for a dual-driver system that hits the mark on objective audio goals, delivering sound with unparalleled clarity.
State-of-the-Art Driver Configuration
The ZERO:RED boasts a double dynamic driver setup, featuring a 10mm base and a 7.8mm driver for mid to treble frequencies. This configuration is fine-tuned to match rigorous R&D standards, offering a superior objective performance.
Smooth and Responsive Audio
A specially crafted ultra-fine CCAW voice coil in the 7.8mm driver ensures a lightweight system that resonates closer to the desired frequency curve. The result is a smoother and more responsive audio experience across all ranges.
Deep and Distortion-Free Bass
The 10mm driver, dedicated to bass, is meticulously adjusted to integrate seamlessly with the new frequency division circuit. This attention to detail leads to significant improvements in measurements such as nonlinear distortion, giving you a richer and cleaner bass response.
High-Quality Cable for Superior Sound
Bundled with a high-quality, silver-plated cable featuring a robust 0.78 2Pin interface, the ZERO:RED delivers pristine sound quality. This cable also offers flexibility for future upgrades, ensuring that your listening experience remains top-notch.
Cutting-Edge Acoustic Performance
The ZERO:RED is designed with TRUTHEAR's latest R&D advancements, optimizing nonlinear distortion for louder volumes and ensuring a sound curve that meets the most discerning audiophile's preference. The collaboration with Crinacle ensures a bass response that's punchy without overpowering the higher frequencies.
Advanced Phase Coherence
With ZERO:RED, experience a consistent full-frequency phase that avoids the common convergence issues found in multi-driver earphones, eliminating any unnatural distortions for a smooth, fatigue-free listening session.
Revolutionary Manufacturing Techniques
ZERO:RED uses DLP 3D printing technology paired with medical-grade resin to form a lightweight, ergonomic design. This innovative approach delivers a comfortable fit and a long-lasting, skin-friendly material that stands up to everyday use.
Commitment to Excellence
TRUTHEAR x Crinacle ZERO:RED In-Ear Headphones are not just another pair of earphones; they represent the pinnacle of acoustic engineering and design, providing an unmatched listening experience that truly honors the music.
