Sennheiser HD 660S Headphones
Cup style
Wearing style
Driver type
Amp required
Sennheiser
The HD 660 S Open-Back Dynamic Headphones from Sennheiser are headphones for the passionate audiophile and are crafted for the most demanding listener. Built with a transducer design that delivers lower harmonic distortion, they provide a natural, lifelike audio experience and can be used to produce crisp bass, transparent mid-frequency response, and a natural treble when connected to high-res players or portable audio devices.
With an impedance of 150 Ohms and a frequency response of 10 Hz to 41 kHz, the HD 660 S headphones are equipped with a choice of cables that feature both balanced (4.4mm Pentaconn) and 1/4" connectors. A 1/4" to 1/8" adapter is also included. This allows you to enjoy reference-class, high-fidelity sound with stationary and mobile audio players alike.
Enjoy the HD 660 S sound in even more listening situations. Thanks to a lower impedance than the previous HD 650 model, they deliver reference-class sound when connected to high-res mobile players. They indulge the demanding listener with aural precision and a comfortable fit.
Made for the demanding listener, the HD 660 S feature powerful performance with crisp bass, detailed mid-frequency response, and gentle, natural treble. These headphones immerse you in the emotion and nuance of the music. They are accurate and transparent.
Built with a transducer design that improves control of the diaphragm movements, the headphones are manufactured with precision stainless-steel fabric that adapts to the contour of the diaphragm. Aluminum voice coils ensure high impulse fidelity. Transducers are carefully selected and paired by hand to ensure consistently narrow tolerances (±1 dB).
With their low impedance of 150 Ohms, the HD 660 S offer reference-class fidelity with high-res mobile players. They come with a choice of cables for just about any occasion. All cables are made of OFC copper, featuring very low handling noise and sturdy para-aramid reinforcement.
The elliptical earcups are shaped to follow the anatomy of the ear, while thick padding on the headband and the replaceable ear cushions provide for hours of listening in comfort.
A nominal impedance of 150 Ohms allows for direct connection to both stationary and mobile high-res Players.
Specifications
Title | Description |
Sensitivity
104 dB |
Total Harmonic Distortion (THD)
< 0,04% |
Frequency Response
9 – 41,500 Hz |
Driver Type | Dynamic |
Driver Materials & Size | |
Headphone Weight | 260 grams |
Warranty
Warranty differs from manufacturer to manufacturer. Warranty covers factory defects but most manufacturers do not cover drops, water damage, driver damage, mistreatment of the product, etc. It is always best to look at the manufacturer's website for the most up to date warranty information.
3 years manufacturer's warranty |
