1 of 6
Sennheiser
Sennheiser HD 450BT Headphones
Regular price $199.95
Sale price $199.95 Regular price $199.95
Wireless
No Fee 365-Day Returns
Don’t love it to start? Don't worry, you have 365-days to return with no fees.
Sennheiser
Step up your wireless audio
Step up to great wireless sound with the new HD 450BT. Whether relaxing at home or on the go, you enjoy an exceptional combination of versatility and superior sound.
The Sennheiser HD Series ‒ your audio companion for every need!
Crafted from high-quality materials, the robust and stylish HD models offer an exceptional combination of versatility and superior sound. At home while listening to a podcast or on the go with your favorite song, you can count on the new HD series to be your ultimate companion for wireless audio – whatever you listen to.
Enjoy your music – without distraction
Thanks to active noise cancellation and a closed back design, the HD 450BT delivers captivating sound that you can enjoy without distraction – even in loud environments. Capture every audio detail in exceptional sound quality, assured by high-quality wireless codec support, including AAC and aptX™ Low Latency.
Your reliable companion on the move
A great companion for travel, the HD 450BT has a superb 30-hour battery life. And this headset can be quickly charged with USB-C to save you valuable time on the move. The compact folding design – available in black or white – has been crafted from high-quality materials to provide the perfect balance of minimalist style, ergonomic comfort, and take-anywhere durability.
Your sound – your decision
Whether you want to turn up the bass or enjoy a natural sound, the Sennheiser Smart Control App makes it effortless for you to tailor the sound to your personal taste – thanks to an intuitive equalizer. Besides battery status and firmware updates, the app features a podcast mode that optimizes the intelligibility of podcasts, audio books, and other speech content.
Follow your intuition, stay connected
Take intuitive control over your music and calls via easy touch buttons on the earcups. Have a truly connected experience through the dedicated Voice Assistant button and Bluetooth® 5.0 support or the additional audio cable.
Smart Control App
Listen to your music the way you want. This free dedicated app for iOS and Android provides an effortless way to control, personalize, update and configure your Sennheiser headphone, headset or soundbar.
What's in the box?
  • HD 450BT Wireless Headphones
  • Audio Cable
  • USB-C Charging Cable
  • Carry Case
  • Quick Guide
  • Safety Guide
Tech Specs
Headphone
Earpiece Design Over-Ear (Circumaural), Closed-Back
Earpiece Connection / Wearing Style Headband
Driver Type Dynamic
Active Noise Cancellation Yes
Controls/Microphone Location Controls: Earpiece (Side Unspecified)
Microphone: Earpiece (Side Unspecified)
Sensors Touch
Foldable Yes
Performance
Frequency Response 18 Hz to 22,000 Hz (Wireless)
Maximum Sound Pressure Level (SPL) 108 dB at 1 kHz
Total Harmonic Distortion (THD) 0.3%
Microphone
Number of Mics 2
Beamforming Support Yes
Type MEMS
Frequency Response 80 Hz to 6000 Hz
Wireless Connectivity
Wireless Modulation π/4 DQPSK, 8DPSK, GFSK
Supported Audio Codecs AAC, SBC, aptX, aptX LL
Bluetooth Profiles A2DP, AVRCP, HFP, HSP
Bluetooth 5.0
Frequency 2.4 GHz (2402 to 2480 MHz)
NFC None
Wired Connectivity
Audio Connector to Source 1 x 1/8" / 3.5 mm Male
Audio Connector to Earpiece 1 x 1/8" / 3.5 mm Female
Battery
Battery Chemistry Lithium-Ion Polymer (LiPo)
Capacity (mAh) 600 mAh
Runtime 30 Hours (BT+ANC)
Recharge Time 2 Hours
DC Input Power 5 VDC
Charging Port USB Type-C
Physical
Weight Headphones:
8.4 oz / 238 g
Packaging Info
Package Weight 1.205 lb
Box Dimensions (LxWxH) 9.2 x 9.2 x 4.1"
