Questyle
Questyle M15i USB Portable DAC & Headphone Amplifier
Amplifier type
Portability
Dual headphone outputs
The M15i, equipped with four current mode amplification engines, supports 3.5mm single-ended and 4.4mm fully balanced output modes,making it suitable for a wide range of apps and devices.
Full Compatibility for True Lossless Enjoyment
During the development, Questyle Labs conducted extensive testing and targeted optimization of M15i's compatibility with mainstream smartphones and tablets. Developers managed to achieve high compatibility with iOS, HarmonyOS, Android versions 5.1, etc. As for PC, it supports Windows 10 version 18.3 and above (driver-free) as well as Mac OS systems. Hence, all Hi-Fi headphone users can enjoy lossless audio on streaming platforms anytime, anywhere.
Apple MFi Certification Ensures
High Performance and Compatibility
"i" in M15i indicates that it has been certified by Apple's MFi program. MFi certification ensures perfect compatibility with iPhone/iPad and the Apple eosystem. It meets Apple's strict requirements for external devices in terms of power consumption and compatibility, avoiding the risk of damage to phones and systems caused by arbitrary connections of USB devices.
Supporting Dynamic Sampling Rate Display
When playing music, the data status indicator will light up.
▪ A single red indicator means PCM data with a sampling rate not exceeding 48kHz.
▪ Dual red indicators represent high-sampling-rate PCM data or DSD audio data.
