1 of 5
Meze
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Open-Box
Regular price $1,699
Sale price $1,699 Regular price $2,000.00
Meze
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Hands holding LIRIC | Headphones.com
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Meze Liric Logo | Headphones.com
Liric – the portable isodynamic hybrid array headphone
Powered by Rinaro Isodynamics
Features
  • Driver type: Rinaro Isodynamic Hybrid Array® MZ4
  • Closed-back, circumaural headphones
  • Lightweight magnesium frame
  • Stainless steel headband with padded cushions
  • Ergonomic ovoid shape
  • Genuine leather headband
Tech Specs:
  • Diaphragm Type – Rinaro Isoplanar® MZ4
  • Frequency response 4 - 92,000 Hz
  • Impedance 30 Ω
  • Nominal SPL 100 dB (1mW/1kHz)
  • Maximum SPL >130dB
  • Total Harmonic Distortion (THD): <0.15% (in the whole frequency range
  • Weight: ~ 390g
Accessories:
  • Case: Gift box with foam inserts - EVA pouch with soft plush interior
  • Included cables: 1.5m soft TPE cable, with aluminum casings, ending with 3.5 mm jack 3m soft TPE cable, with aluminum casings, ending with 3.5 mm jack
  • Headphone termination: 3.5 mm TRS jack
  • Included adapters: 6.3mm gold-plated jack Airplane jack
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Liric headphones laid horizontally | Headphones.com
Award-Winning Technology In A Portable Frame
LIRIC features the state-of-the-art technology developed by Rinaro, re-engineered for day-to-day use. The MZ4 Isodynamic Hybrid Array driver was purposefully scaled down and tuned to deliver a similar audio experience with its larger counterpart found in the Empyrean.
Combined with the closed-back design, it helps preserve the original clarity and emotion of your favorite music through enhanced sound and minimized external noise. Each driver is entirely hand assembled and tested in Rinaro's industrial facility in Ukraine.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Diagram of driver layers: casings, isoplanar layer plus hybrid magnet array | Headphones.com
MZ4 Casing
Reinforced polymer housing designed to withstand the demanding 10,7N load generated by the Hybrid Magnet Array.
MZ4 Isoplanar® Diaphragm
Weighing only 0.08g with a large active area of 3507mm.
MZ4 Hybrid Magnet Array
Symmetrically placed on either side of the diaphragm our neodymium magnets are arranged into a Hybrid Array to create a 0.3 Tesla Isodynamic magnetic field required for a uniform activation across the whole diaphragm surface.
MZ4 Isodynamic Hybrid Array Driver
We have continued our collaboration with Rinaro Isodynamics to create the MZ4 Driver.
LIRIC is the first closed-back headphone to be powered by Rinaro’s Isodynamic Hybrid Array driver. Created exclusively for Meze Audio, the MZ4 driver offers the same dual shaped voice coil array seen in the Meze Audio Empyrean. Over 30 years of R&D have gone into developing this technology, resulting in one of the lightest and most advanced planar magnetic drivers on the market.
A new innovation to the MZ4 driver developed in-house by Rinaro Isodynamics is the Phase-XTM system, which improves ambience and spatial sound imaging, often found to be a problem in closed back headphone designs.
Ultra Low Distortion
Total harmonic distortion (THD) measures under 0.15% in the whole frequency range.
Lightweight
71g combined driver weight designed to create a headphone that offers comfortable listening on the go.
Phase-X™ System
Improved ambience and spatial sound imaging through innovative technology.
Ultra High Resolution Audio
Upper frequency limit of audio reproduction is 92,000 Hz.
Easy-to-Drive
100db@1mw/1kHz; 30Ω Can be driven by almost any portable source without needing amplification.
Scaled Flagship Isodynamic Hybrid Array Technology
One of the most sophisticated and advanced planar magnetic technologies in the world has been scaled down for portable use.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Isolated driver unit areas | Headphones.com
Improved Efficiency at Higher Frequencies
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Comparison between conventional planar array and isodynamic hybrid array | Headphones.com
At frequencies above 10kHz, where sound wave length is smaller than the cushions inner cavity, the sound field becomes diffused with an amount of the direct and reflected sound waves within the ear canal.
A significant increase of direct sound waves was achieved by positioning the most efficient part of the diaphragm in mid-high frequencies directly over the ear canal, resulting in improved 3D imaging and spatial localization.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Dramatic image of Lirics on case | Headphones.com
Phase-X™, A Revolution In Sound Imaging
An innovation to the MZ4 driver is the Phase-X™ system created by Rinaro as a way to minimize phase distortion issues typically found in closed back headphone designs. This patent-pending technology helps create an immersive spatial sound imaging.
The Phase-X™ system improves the accuracy of spatial imaging in-line with its open back counterparts, especially noticeable on binaural recordings.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Diagram of sound imaging with original source recording | Headphones.com
Original Source Recording
Absolute linear phasing offers the listener the original spatial image as it was recorded. This includes information from the instrumentation as well as the recording environment itself.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Diagram of conventional sound imaging | Headphones.com
Nonlinear Phasing
Nonlinearities in phase response noticeably affect the reproduction of the spatial image of the original recording. (illustration)
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Diagram of Phase-X™ linearization system sound imaging | Headphones.com
Phase-X™ Linearization System
With the addition of the Phase-X™, Liric achieves a more linear phase response and a faster transient response decay. This allows for a more faithful reproduction of transient sounds and improves ambience and spatial imaging for the listener, taking them closer to the environment of the original source recording.
Meze Audio LIRIC Closed-Back Planar Magnetic Headphones - Headband, closeup of air flow channels | Headphones.com
Optimal Airflow Control
Padded headband cushions are symmetrically placed in a “+” shape to allow proper air flow, and lowers the heat and humidity buildup. Covered in genuine leather, the headband is perfectly tuned for optimal pressure distribution it follows the structure of the head, creating firm and even contact.
Just like all Meze Audio headphones, LIRIC is easily adjustable for a sturdy, yet comfortable feel that fits most head shapes.
