Focal
Focal Celestee High-End Headphones
Elegant design and remarkable sound performance
Cup style
Wearing style
Driver type
The Celestee is the true successor to Focal's previous closed-back, the Elegia. Styled in navy-blue with copper finish, the Celestee is absolutely gorgeous to behold with the sound to back it up. This is one of the best closed-back headphones next to Focal's own Stellia and is a must for anyone looking for a good pair of closed-back headphones.
The Celestee headphones boast outstanding tonal balance: incredible bass extension with precise treble and high-mids to delight any music lover.
Celestee is a set of high-end headphones combining elegant design and remarkable sound performance. They incorporate the latest Focal technologies: 15/8" (40mm) Aluminium/Magnesium ‘M’-shaped dome full-range speaker drivers and acoustic treatment within the earcups to prevent resonance.
Focal Celestee Highlights - One Sheet
In terms of design, their earpads, headband and earcups boast a Navy Blue semi-aniline leather finish. Their Soft Copper details (speaker driver grille, cable connectors, rings, etc.) create a sophisticated look. Take them everywhere with you, thanks to their rigid carrying case, also in Navy Blue and Soft Copper colours.
Highlights
- Closed-back headphones for home and on-the-go use
- Outstanding design, fine materials and Navy Blue finishes, with Soft Copper details
- Remarkable sound performance: incredible bass extension, and tonal balance unrivalled in their category
- Low impedance (35 Ohms) to ensure uncompromising use with a portable audio player
What's In The Box?
- Focal Celestee Closed-Back Over-Ear Headphones
- Carrying Case matching Celestee colours
- 4 ft. (1.2m) mini-jack (3.5mm) cable with a 1/4" (6.3mm) adapter
- Owner's manual
Specifications
Title | Description |
Sensitivity
105dB SPL / 1 mW @ 1 kHz |
Total Harmonic Distortion (THD)
0,1 % @ 1 kHz / 100 dB SPL |
Frequency Response
5Hz – 23kHz |
Driver Type | Electrodynamic full-range |
Driver Materials & Size | 40mm Aluminium/Magnesium ‘M’-shaped dome |
Headphone Weight | 430 grams |
Warranty
Warranty differs from manufacturer to manufacturer. Warranty covers factory defects but most manufacturers do not cover drops, water damage, driver damage, mistreatment of the product, etc. It is always best to look at the manufacturer's website for the most up to date warranty information.
3 years manufacturer's warranty |
Written review
Focal Celestee Review - Best New Closed-Back Headphone in 2021?
FAQs
