Audeze
Audeze LCD-X Headphones | Premium Package
Cup style
Wearing style
Driver type
Amp required
The Audeze LCD-X Premium package ships with 1 x Single-Ended 1/4" Cable, 1 x Balanced 4-Pin XLR Cable along with Audeze's Premium Pelican travel case. The LCD-X in the Premium Package and Creator's Edition are the same headphones.
Don't need the balanced cable and premium case? Check out the Audeze LCD-X Creators Edition.
The Audeze LCD-X High-Performance Reference Planar Magnetic Headphones (Lambskin Leather) is designed for professional mixing, mastering, and reference level personal Hi-Fi listening when connected to a low powered external headphone amplifier or portable device. The headphones are sensitive enough to be driven by portable music players such as iPods, iPhones, and other smartphones. Instead of utilizing traditional dynamic cone drivers, the headphones implement a neodymium magnetic planar transducer design to deliver a frequency response of 5 to 50,000 Hz with a THD of less than 1%, an impedance of 70 Ω, an efficiency of 95 dB per 1 mW, and a total output SPL of over 130 dB when driven by 15 watts.
Magnetic planar technology differs from traditional dynamic cone designs by suspending a thin lightweight diaphragm within a parallel magnetic plane comprised of an array of magnets. The diaphragm is much lighter when compared to a traditional dynamic cone and has a printed circuit spread across a thin-film substrate on the surface of the diaphragm as opposed to a cone attached to a voice coil. When the audio signal from the amplifier reaches the circuit, it magnetizes the diaphragm within the field and produces sound.
The benefits of a magnetic planar design include faster transient response due to the lighter diaphragm, a wide frequency with low distortion, better heat dissipation, fewer moving parts for greater durability without the kind of sonic degradation that cones are susceptible to, and better amplifier compatibility because the circuit functions as an almost entirely restive load.
The magnetic structure creates a uniform magnetic field across the diaphragm without the need for additional ferromagnetic material traditionally found in other planar headphones to remove magnetic interference, reduce harmonic distortion, and lower overall weight. The headphones also feature Audeze’s patent-pending Fazor elements that guide and manage the flow of sound through the earcups for a more enveloping sound stage and improved frequency extension.
The headphone earcups are made of anodized aluminum with black lambskin leatherette earpads. They come with a ruggedized travel case, a 1/4" to 4-pin mini-XLR cable. They are handcrafted in the USA and a personalized frequency response graph is available through support@audeze.com
*Headphones.com is very pleased to announce that you have even more options to pay for your Audeze LCD-X Planar Magnetic headphones! Now when you hit the Pay with Crypto button, you have the option to pay with currencies such as NANO, Bitcoin, Litecoin, Ethereum and more! We are very excited to able to give you these options now and for the future!*
