HiFi Rose RS201e HiFi Network Media Player, Streamer and Headphone Amplifier - Open Box
Amplifier type
Wired, Wireless
Portability
HiFi Rose
The HiFi Rose RS201E is the HiFi Network Media Player that provides High Quality Sound, Ultra High Pixel Stream together with various type of Multi Media services based on HiFi Design Expertise and ROSE platform.
Modernized Simplification
Premium Design
Harmonized Design by upper class frame consist of aluminum body with corner, volume knob, power button and wide view touch screen makes its whole shape be exceptional.
HiFi Audio & UHD Video
Multimedia Playback
Music
Play List that Audio Video files in the local storageas USB. MSD. SSD makes its convenient use.
* Supported Audio Playback Formats
- MQA, WAV. FLAC. WMA. MP3. APE. DFF. DSF, PCM 8kHz~384kHz (8/16/24/32bit per Sample)
- Native DSD : DSD64(1bit 2.8MHz) / DSD128(1bit 5.6MHz)/DSD256(1bit 11.2MHz)
Video
You can play movies in local storage (USB/Micro SD/SSD) and NAS / network shared drives. If you connect ROSE and TV with HDMI cable, you can watch movies on the big screen.
* Support Video format
- H.264/AVC Base/Main/High/High10 profile@level5.1; up to 4Kx2K@30fps, MPEG-1, MPEG-2, MPEG-4 H.263, H.264, H.265, VC-1, VP9, VP8, MVC, H.265/HEVC, Main/Main10 profile@ level 5.1 High-tier; up to 4Kx2K@60fps
ROSE Podcast
Podcast channels provided by iTunes to reflect popularity, ROSE server offer channels and it is organized by topic Create your own subscriptions, playlists and organize your favourite channels and content.
Radio
You can listen to the radio channel from USA to Germany around 800 channels.
RS201E Supports 4K with HDMI
- Ultra High Definition
High Quality Sound
Studio Mastering Quality Sound Playback
PCM32bit/384khz, Native DSD256- 32bit/11.2MHz
Supporting Latest High Resolution PCM32bit-384kHz and Native DSD32bit-11.2MHz provide full and dynamic sound through Reference 32bit High Performance DAC.
High Speed Driver Variation Technique and Embedded Pure Path Ultra HD Power Amp. Provide Super Audio Quality of Ultra Low Distortion and stable sound quality covering whole range.
Harmonization between vacuum amp. and reference grade amp. PreAmp in 122dB SNR(-132dB THD+N)supports Studio Mastering Quality Sound.
The HiFi Rose RS201E includes MQA technology which enables you to play back MQA audio files and streams, delivering the sound of the original master recording.
All-in connectivity
Various Device Connection
- Supports DLNA, Airplay Service in Network and A/V files stored Smartphone, Tablet, NAS etc...
RS201E provides the most latest Interface and Device taking on market trend and customer needs as Line In PreAmp Out. Digital(optical) I/O. Speaker Out.
Headphone Out. HDMI compatible with High Quality DAC. AMP. Speaker. TV etc.
