KEF Kube 15 MIE Powered Subwoofer
365-day returns
KEF
Unmatched Deep Bass for Large Spaces
The KEF Kube 15 MIE stands as the pinnacle of the Kube range, designed specifically to fill large rooms with deep, earth-shaking bass. Equipped with a formidable 15-inch driver and powered by a 300W (RMS) Class D amplifier, this subwoofer is your gateway to experiencing the most immersive bass performance possible. Enhanced by the Music Integrity Engine®, the Kube 15 MIE ensures that you feel every beat with unparalleled depth and dynamics.
Designed to Complement Any Room
With its sleek, sealed cabinet design, the Kube 15 MIE not only promises optimal placement flexibility but also adds a touch of modern elegance to your space. Its contemporary aesthetic effortlessly integrates into your home decor, making it a statement piece that complements any interior design theme.
Innovative Music Integrity Engine® for Superior Sound
At the core of the Kube 15 MIE's exceptional performance lies KEF's proprietary Music Integrity Engine®. This advanced DSP technology harmonizes every component of the subwoofer to work in perfect unity, delivering deep, precise bass with the innovative iBX Intelligent Bass Extension. Experience sound as you've never before, with every note and beat brought to life.
Power and Precision Combined
The Kube 15 MIE is designed to amaze with its front-firing long-throw driver, boasting a large cone area and high excursion for superior sound output at lower frequencies. Supported by a cool-running 300W Class D RMS amplifier, this subwoofer ensures an enhanced listening experience without compromising on performance.
Versatility for Every Entertainment Need
Ideal for elevating the audio experience of movies, music, TV, and gaming, the Kube 15 MIE's versatile design ensures it fits seamlessly into any entertainment setup. Its mid-sized stature allows for easy placement in any room, ensuring you get the best possible sound regardless of space.
Wireless Freedom with Effortless Integration
Experience the convenience of wireless audio with the Kube 15 MIE, thanks to the KW1 adapter. This feature allows for optimal subwoofer placement without the hassle of cables, ensuring high-quality sound transmission for a truly immersive audio experience.
Connectivity Made Simple
The Kube 15 MIE offers a range of connection options, including KEF SmartConnect and speaker-level inputs, making it a breeze to integrate into any existing system. Whether you're setting up a new home cinema or enhancing your music listening space, connectivity is straightforward and simple.
Customizable Listening Experience
With three room position EQ options, the Kube 15 MIE is designed to perform exceptionally, regardless of its placement in your room. Combined with multiple power modes, including 'Auto wake up', 'Always on', and '12V trigger', this subwoofer is ready whenever you are, ensuring your music or movies sound their best at all times.
A Legacy of Sound Innovation
As part of KEF's esteemed lineup of subwoofers, the Kube 15 MIE brings home the power of deep, detailed bass with unmatched acoustic accuracy. Dive into the heart of the action with a subwoofer that embodies over 60 years of award-winning innovation in speaker design, offering a modern immersive sound experience like no other.
In the Box
- Kube 15 MIE subwoofer
- Power cord
- Euroblock speaker level connector
- User manual and warranty information
Discover the ultimate audio experience with the KEF Kube 15 MIE Powered Subwoofer, where deep bass meets elegant design and advanced technology.
KEF Kube 15 MIE Technical Specifications
Feature | Specification |
Design | Powered Subwoofer (Sealed) |
Drive units | 1 x 380mm (15in.) |
Frequency response | 20Hz - 140Hz (±3dB) |
Max output | 116dB |
Amplifier type | Class-D |
Amplifier power | 300W RMS |
Variable low pass filter | 40Hz – 140Hz, LFE |
Input | RCA phono sockets, Speaker level inputs, Expansion port for KW1 |
Power requirements | 100 - 240V, 50/60 Hz |
Power consumption | 300VA |
Dimensions (H x W x D) with rear panel and feet | 519 x 500 x 515 mm (20.4 x 19.7 x 20.3 in) |
Weight | 27.5kg |
