Topping L30 Headphone Amplifier - Open Box
Amplifier type
Portability
Topping
All Topping L30s are with the latest serial numbers and protections.
The TOPPING L30 Headphone Amp is the companion to the highly reviewed TOPPING E30 DAC. It can be used as an amplifier or a pre-amplifier, comes equipped with NFCA modules like that in TOPPING's flagship A90 Amp, has 3-step gain settings, and is certified Hi-Res Audio.
The L30 uses NFCA (Nested Feedback Composite Amplifier) that allows it to drive low impedance headphones with ease. It has an ultra-low noise level of 0.3uV that blows out the competition, while producing a high dynamic range of 141dB with no audible noise or dark backgrounds in sensitive IEMs.
High voltage swing of 26Vp-p, power of 3600mW per channel, and output impedance of less that 0.10 ohms let the L30 drive power hungry headphones with wide range of impedance. The three gain settings add to the ability of the L30 to drive a wide range of devices. Finally, the L30 can also be used as a pre-amp and again produces high performance numbers. Output impedance in pre-amp mode is as low as 20 ohms.
Specs:
- Outputs: RCA Out, 6.35mm Single Ended
- Inputs: RCA In
- NFCA (Nested Feedback Composite Amplifier)
- Ultra-Low Noise of 0.3uV
- Dynamic Range of 141dB
- Can drive sensitive IEMs to power demanding headphones
- Pre-Amp Functionality
- Amp and Pre-Amp performance numbers provided in the images
In The Box
- Topping L30 (Black or Silver)
- AC Adapter
- 6.3mm to 3.5mm Adapter
- User Manual
- Warranty Card
