1 of 4
Topping
Topping D30 Pro Desktop DAC
Regular price $299
Sale price $299 Regular price $399.00
Topping
Regular price $299
Powerful 4 x CS43198 DAC Chips
What changes can a quad DAC bring? The answer is in TOPPING newly launched Topping D30 PRO Desktop Digital to Analog Convertor (DAC). With the use of 4*CS43198 chips, it provides a total of 8 full balanced channels, each of which is arranged in parallel by 4 conventional balanced channels. The increase in output capability will bring changes in the sound and the spec will be improved
Optical/Coaxial/USB Inputs, RCA/XLR Output
The Topping D30 Pro Desktop DAC supports USB/ Coaxial/ Optical inputs, USB maximum support PCM 32bit/ 384kHz, DSD256 (Native), DSD128 (Dop); D30pro has full balanced XLR output and single ended RCA output. You can choose XLR only,"RCA only" or XLR+RCA output to meet different usage in the multiple systems.
Preamplifier Function
The Topping D30 Pro Desktop Digital to Analog Convertor (DAC) has preamplifier function so you can control the output volume on the front panel or use remote control. It’s noise is lower than other similar products making it suitable for connecting to power amplifiers or monitor speakers while also help you leave the budget of a preamp.
What Effort We’ve Made
CPLD focusing on clock processing and digital signal optimization, restoring what t he digital signal should be. We use up to 8 independent LDOs to supply power to different loads, so there is no longer interference between different loads. Both RCA and XLR have reached the 120dB SINAD, so that RCA transmission can also have same excellent performance as XLR. .
Make it A Combo
The TOPPING A30 Pro Desktop Headphone Amp + TOPPING D30pro Desktop DAC combination have a specifically redesigned NFCA module and custom functions for better resolution and output for your HiFi system
Specifications
  • USB IN: PCM 44. 1 kHz-384kHz/16bit-32bit
  • DSD DSD64-DSD256 (Native)、DSD64-DSD128 (Dop)
  • COAX/OPT IN: PCM 44. 1 kHz-192kHz/16bit-24bit
  • DSD DSD64(Dop)
D30 pro Decoding parameters (USB In@96kHz)
LINE OUT RCA:
  • THD+N@A-wt: <0.0001%@1kHz
  • THD@No-wt 45kBw: <0.0004%@20-20kHz
  • SNR@A-wt: 127dB@1kHz
  • Dynamic range@A-wt: 127dB @1kHz
  • Frequency Response:20Hz-20kHz(+0.1dB)
  • 20Hz-40kHz(+0.3dB)
  • Output Voltage: 2Vrms@0dBFS
  • Noise @A-wt: < 0.9uVrms
  • Crosstalk: -116dB@1kHz
  • Output Impedance: 20Ω
LINE OUT XLR:
  • THD+N@A-wt: <0.00009% @1kHz
  • THD@No-wt 45kBw: <0.0004 % @20-20kHz
  • SNR@A-wt: 132dB@1kHz
  • Dynamic range@A-wt: 132dB@1kHz
  • Output Voltage: 4Vrms@0dBFS
  • Noise @A-wt: < 1.1uVrms
  • Crosstalk: -145dB@1kHz
  • Output Impedance: 40Ω
What's In the Box?
  • Topping D30 Pro Desktop DAC
  • Remote Control
  • USB Cable
  • AC Cable
  • User Manual
  • Warranty Card
