1 of 4
SMSL
SMSL M200
SMSL M200
Regular price $279.99
Sale price $279.99 Regular price $279.99
365-day returns
SMSL
SMSL M200
The SMSL M200 DAC is the high resolution bluetooth companion DAC for theĀ SMSL SP200 THX Headphone Amplifier. The M200 and SP200 together complete a great sounding sound system from SMSL. This DAC uses the AK4497EQ D/A chip from Japanese chip maker AKM to produce a performance that is top tier for the price.
The M200 is Bluetooth 5.0 compatible, has a second generation XMOS chip, and comes with a high performance audio clock system. ItĀ has a PCM sampling rate of 32 bit/ 768 kHz and supports DSD 512 native playback. Finally, the M200 comes with six digital filter modes and includes a remote control for comfortable use.
Specs:
  • Inputs: USB, Coaxial, Optical, Bluetooth
  • Outputs: RCA, Balanced XLR
  • Output Level:
    • RCA: 2Vrms
    • XLR: 4.1Vrms
  • SNR (A-WTD): 125dB
  • Dynamic Range (A-WTD):
    • RCA: 123dB
    • XLR: 125dB
  • THD+N (UN-WTD): -116dB, 0.00015%
  • Bluetooth:
    • UAT: 24bit/192kHz @ 1200kbps (-1200kbps/900kbps/600kbps)Ā
    • LDAC:Ā 24bit/96kHz @ 990kbps (-990kbps/660kbps/330kbps)Ā
    • aptX-HD: 24bit/48kHz @ 576kbps
    • aptX:Ā 16bit/44.1kHz @ 352kbps
    • SBC: 16bit/44.1kHz @ 328kbps
    • AAC: 16bit/44.1kHz @ 320kbps
  • USB Transmission: Asynchronous
  • USB Compatibility: Windows 7/8/8.1/10, Mac OS X 10.6 or later, Linux
  • Bit Depth:
    • USB: 1 - 32bit
    • Optical/Coaxial: 16 - 24bit
  • Sampling Rate:
    • USB: 44.1 - 768kHz (DSD64, DSD128, DSD256, DSD512)
    • Optical/Coaxial: 32 - 192kHz
  • Power Consumption: 3.5 W
  • Standy Power: <0.1W
  • Size: 160 x 43 x 168 mm (w x h x d)
  • Weight: 0.68 kg
