SMSL DA-9 Bluetooth 5.0 Power Amplifier
Portability
365-day returns
SMSL
Bluetooth Digital Amplifier
2 x German Infineon’s new technology class D power amplifier chip, higher quality, efficiency up to 92%, further reducing power consumption;
Using NJRC’s electronic volume control chip NJW1194 from Japan, precise volume control and low distortion;
The true fully balanced design, from input to speaker output, greatly reducing distortion caused by signal transmission;
Built-in SMSL SDB patented sound and treble/bass adjustment for easy matching of a variety of speakers and music;
Subwoofer pre out for 2.1 system application.
New Bluetooth 5.0 reception, better sound quality, longer transmission distance, support APT-X!
All aluminum alloy CNC precision processing shell, anodizing technology and chamfering process, exquisite workmanship and delicate touch;
Color LCD display and user-friendly operating system are simple and easy to understand, equipped with full-featured remote control function;
Low power standby function to meet the latest European ErP2 standard;
A large number of professional Hi-Fi audio components are used to enhance the sound experience;
High quality gold-plated input and output terminals;
Perfect protection circuit for overheating, overcurrent, etc.
Built-in high quality power supply, specially designed for audio!
Dimensions
Specifications
Inputs |
XLR, RCA, BT |
THD+N |
0.003% |
SNR |
111dB |
Channel separation |
96dB |
Input sensitivity/input impedance |
250mV/47kΩ |
Output power |
150W×2 (2Ω)/90W×2 (4Ω)/50W×2 (8Ω) |
Power consumption |
40w (normal volume) |
Standby power |
0.5W |
Dimensions |
187.5×154×40mm (W×H×D) |
Weight |
0.96kg |
Weight (with package) |
1.46kg |
