SMSL
Portability
SMSL D3 Desktop DAC
SMSL D3 Desktop DAC
Regular price
$3,499.99
Sale price
$3,499.99
Regular price
$3,499.99
Unit price
per
Portability
On back order
365-day returns
SMSL
SMSL D3 Desktop DAC
Regular price
$3,499.99
Sale price
$3,499.99
Regular price
$3,499.99
Unit price
per
Every detail is part of its high-end design.
- 4 pieces of legendary R-2R chip PCM1704U-J from BB, 2 pieces per channel, fully balanced design, maximize chip performance!
- USB uses XMOS second generation 16 core processor XU216, supports native DSD512 and 32-bit 768kHz!
- Top digital filter chip SM5847.
- The clock system uses two accusilicon ultra-low phase noise crystal oscillators.
- Using Altera's high-speed CPLD to process the clock and reduce jitter.
- Support LVDS level I2S transmission (using HDMI interface), can transmit digital audio with the lowest jitter!
- Built in low clock jitter VCXO and PLL, support access to external clock!
- Full function remote control with color LCD and newly developed user interface.
- Use 7 OPA1612 top OP-AMPs from TI.
- High precision, low temperature drift, resistor and capacitor are widely used.
- Low noise discrete component power supply circuit.
- Customized low-noise sealed toroidal transformer manufactured by Noratel, UK;
- All aluminum alloy CNC shell, separate power supply and motherboard design, effectively isolate power interference.
Specifications
Input | USB / Optical / Coaxial / AES (EBU) |
Output | RCA /XLR |
THD+N | 0.0001% |
Dynamic range | 112dB |
SNR | 112dB |
USB transmission | Asynchonization |
USB compatibility | Windows 7/8/8.1/10, Max OSX, Linux |
Bit depth |
USB: 1-bit, 16-32bit Optical/coaxial/AES (EBU): 1-bit, 16-24bit |
Sampling rate, USB/PS |
PCM: 44.1-768kHz DSD: 2.8224-22.5792MHz |
Sampling rate, Optical/Coaxial/AES (EBU) | PCM: 44.1-192kHz |
Power consumption | 10W |
Standby power | <0.8W |
Size | 280 x 240 x 51mm ( W x H x D) |
Weight | 3.96kg |
Sold out
