Sennheiser PXC 550-ii
Cup style
Wearing style
Driver type
Wireless
Sennheiser
Designed for all-day use, the PXC 550-II Wireless Active Noise-Canceling Over-Ear Headphones from Sennheiser provide you with up to 30 hours of battery life, padded earcups and headband, and easy access to your smartphone. The PXC 550-II headphones have an integrated voice assistant button that connects you to your phone's digital assistant, such as Google Assistant, Siri, or Alexa. Once connected, a beamforming 3-microphone array helps to focus onto your voice for clearer commands, questions, and hands-free conversations.
Featuring active noise-canceling technology, the PXC 550-II headphones will filter out ambient noises and sounds that can distract you from your favorite music or an important conversation. The degree of noise cancellation can be customized via the Sennheiser Smart Control app for iOS and Android devices, so you can tone it down or activate Transparent Hearing to get back in touch with your surroundings when needed. The Smart Control app also features a built-in equalizer to optimize sound quality for your audio content.
Automatic On
Smart Pause
Additional Features
Rotating earcups
Support for Bluetooth 5.0, aptX, and aptX Low Latency
Specifications
Title | Description |
Sensitivity
110 dbSPL (passive : 1 kHz/1V RMS) |
Total Harmonic Distortion (THD)
When driving headphones at high volumes, it is possible for the diaphragm (the âspeakerâ inside the headphones) to be unable to move fast enough. This leads to distortion, manifesting itself as crackling, popping or the alteration of musical notes. Most headphones will fall below 1% THD.
<0,5% @ 100 dBSPL / 1kHz |
Frequency Response
Headphone frequency response refers to the frequency-specific sensitivity of the output. Frequency responses show the range that headphones are capable of reproducingâa graph shows which frequencies are accentuated over others. The ideal range covers the audible sound range of 20 Hz â 20 kHz.
17 â 23,000 Hz (-10db) |
Driver Type | Dynamic |
Driver Materials & Size | |
Headphone Weight | 227 grams |
Warranty
Warranty differs from manufacturer to manufacturer. Warranty covers factory defects but most manufacturers do not cover drops, water damage, driver damage, mistreatment of the product, etc. It is always best to look at the manufacturer's website for the most up to date warranty information.
2 years manufacturer's warranty |
Written review
