{"product_id":"noble-audio-osprey-wireless-in-ear-headphones-open-box","title":"Noble Audio Osprey Wireless In-Ear Headphones - Open Box","description":"\u003cp\u003eThe Noble Audio Osprey brings the character of Noble’s in-ear monitors into a true wireless headphone built for daily use. It is the most accessible model in Noble’s wireless lineup, but it still carries the things people come to Noble for: a more considered tuning, a hybrid driver design, and a visual identity that feels crafted rather than mass-produced.\u003c\/p\u003e\n\u003cp\u003eAt $199, Osprey is not trying to be another disposable pair of wireless earbuds. It is an entry point into the Noble ecosystem, made for listeners who want something easy to use every day without giving up on sound, comfort, or design. You get active noise cancellation, Transparency Mode, LDAC support, Bluetooth 5.4, app-based EQ, and a compact charging case, all wrapped around a dual-driver acoustic design that gives Osprey more depth and refinement than a typical single-driver true wireless earbud.\u003c\/p\u003e\n\u003ch3\u003eNoble Sound, Made for Everyday Listening\u003c\/h3\u003e\n\u003cp\u003eOsprey uses a hybrid driver system with a 10mm dynamic driver and a custom balanced armature in each earpiece. The dynamic driver gives the sound its weight, warmth, and low-end control. The balanced armature adds clarity and separation through the mids and treble, helping vocals, instruments, and small details come through with better focus.\u003c\/p\u003e\n\u003cp\u003eThe tuning is clean, balanced, and easy to enjoy. Bass has enough presence to keep music engaging, but it does not overwhelm the midrange. Vocals sound natural and clear. Treble has enough extension to bring out detail without turning sharp or fatiguing. It is the kind of sound that works across a full day of listening, whether you are playing music, watching video, taking calls, or using Osprey on the move.\u003c\/p\u003e\n\u003ch3\u003eA True Wireless Earbud That Still Looks Like a Noble\u003c\/h3\u003e\n\u003cp\u003eOne of the easiest ways to spot a Noble product is the faceplate, and Osprey keeps that tradition alive. Each earpiece features a distinctive acrylic faceplate with layered, fluid patterns that give the design depth and individuality. It looks more like a small universal IEM than a generic wireless earbud, which is exactly what makes it feel different.\u003c\/p\u003e\n\u003cp\u003eThe shell is lightweight and ergonomic, with a fit designed for comfort, stability, and consistent passive isolation. Osprey is built to be worn every day, but it still has the premium feel and visual personality that Noble fans expect.\u003c\/p\u003e\n\u003ch3\u003eWireless Features That Fit Real Life\u003c\/h3\u003e\n\u003cp\u003eOsprey is built around Bluetooth 5.4 and the Airoha 1571 chipset for stable modern wireless performance. Codec support includes SBC, AAC, and LDAC, giving compatible Android devices access to higher-quality wireless playback while keeping broad compatibility with phones, tablets, laptops, and everyday sources.\u003c\/p\u003e\n\u003cp\u003eActive Noise Cancellation helps reduce outside noise when you want to focus, while Transparency Mode lets the world back in when you need awareness. Multipoint connectivity makes it easier to move between devices, and TrueWireless Mirroring helps keep the experience smooth whether you are listening to music, taking a call, or switching from your laptop to your phone.\u003c\/p\u003e\n\u003ch3\u003eDesigned to Stay in Rotation\u003c\/h3\u003e\n\u003cp\u003eBattery life is rated for up to 7 hours with ANC off and up to 5 hours with ANC on. The 500mAh charging case extends your listening time, and a 10-minute quick charge gives you roughly 2 hours of playback when you need a quick top-up.\u003c\/p\u003e\n\u003cp\u003eThe Noble Audio app adds EQ control and over-the-air updates, giving you more room to shape the sound and keep the earbuds current over time. Osprey keeps the experience simple, but not stripped down. It gives you the wireless features you actually use, the design language Noble is known for, and a sound that feels more polished than the price suggests.\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eMost accessible true wireless model in Noble Audio’s lineup\u003c\/li\u003e\n\u003cli\u003eHybrid dual-driver design with 10mm dynamic driver and custom balanced armature\u003c\/li\u003e\n\u003cli\u003eClean, balanced tuning with controlled bass, natural mids, and clear treble\u003c\/li\u003e\n\u003cli\u003eBluetooth 6.0 with Airoha 1571 chipset\u003c\/li\u003e\n\u003cli\u003eSBC, AAC, and LDAC codec support\u003c\/li\u003e\n\u003cli\u003eActive Noise Cancellation for reducing outside noise\u003c\/li\u003e\n\u003cli\u003eTransparency Mode \/ Hearing Through for environmental awareness\u003c\/li\u003e\n\u003cli\u003eMultipoint connectivity for switching between devices\u003c\/li\u003e\n\u003cli\u003eTrueWireless Mirroring for seamless wireless operation\u003c\/li\u003e\n\u003cli\u003eDual microphones with cVc noise reduction for clearer calls\u003c\/li\u003e\n\u003cli\u003eUp to 7 hours playback with ANC off\u003c\/li\u003e\n\u003cli\u003eUp to 5 hours playback with ANC on\u003c\/li\u003e\n\u003cli\u003e10-minute quick charge provides approximately 2 hours of playback\u003c\/li\u003e\n\u003cli\u003eUSB-C charging\u003c\/li\u003e\n\u003cli\u003eNoble Audio app support with EQ and OTA updates\u003c\/li\u003e\n\u003cli\u003eDistinctive acrylic faceplates with layered, fluid patterns\u003c\/li\u003e\n\u003cli\u003eCompact aluminum charging case\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width: 100%; border-collapse: collapse;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eProduct Type\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eTrue wireless in-ear headphones\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Configuration\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eHybrid dual-driver system\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eDrivers\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e10mm dynamic driver + custom balanced armature\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eChipset\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eAiroha 1571\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eBluetooth\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eBluetooth 6.0\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eSupported Codecs\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eSBC, AAC, LDAC\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eFrequency Response\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e20Hz to 40kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eSensitivity\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e104 +\/- 3dB at 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eImpedance\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e32Ω\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eNoise Control\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eActive Noise Cancellation and Transparency Mode \/ Hearing Through\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eConnectivity\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eMultipoint connectivity, TrueWireless Mirroring\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eMicrophones\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eDual microphones with cVc noise reduction\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eBattery Life\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eUp to 7 hours with ANC off, up to 5 hours with ANC on\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eQuick Charge\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e10 minutes for approximately 2 hours of playback\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eCharging Case Battery\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e500mAh\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eCharging\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eUSB-C\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eApp Support\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eNoble Audio app with EQ and OTA updates\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Noble Audio","offers":[{"title":"Default Title","offer_id":43242929586247,"sku":"TWS016-OPEN","price":179.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/Osprey-740.jpg?v=1780411806","url":"https:\/\/headphones.com\/products\/noble-audio-osprey-wireless-in-ear-headphones-open-box","provider":"Headphones.com","version":"1.0","type":"link"}
