{"product_id":"noble-audio-fokus-artemis-wireless-headphones-open-box","title":"Noble Audio FoKus Artemis Wireless Headphones - Open Box","description":"\u003cp\u003eThe Noble Audio FoKus Artemis is a flagship wireless over-ear headphone built for listeners who want high-end sound without giving up the convenience of a modern everyday headphone. It brings together a rare hybrid three-driver system, premium wireless performance, active noise cancellation, USB audio, wired listening support, and a self-replaceable battery in one refined full-size design.\u003c\/p\u003e\n\n\u003cp\u003eArtemis is designed to feel like a true Noble headphone first. The sound is built around scale, detail, and immersion, with a dynamic driver for weight and impact, a balanced armature for clarity and articulation, and a planar driver for speed and openness. It is a more ambitious approach than a typical wireless headphone, giving Artemis the kind of layered, high-resolution presentation that better matches what serious listeners expect from Noble.\u003c\/p\u003e\n\n\u003ch3\u003eHybrid Three-Driver Sound\u003c\/h3\u003e\n\n\u003cp\u003eMost wireless over-ear headphones rely on a single dynamic driver. FoKus Artemis takes a different path with a hybrid driver configuration that combines three driver technologies inside each side of the headphone. The dynamic driver brings body, punch, and low-end authority. The balanced armature adds definition through vocals, instruments, and upper-frequency detail. The planar driver contributes speed, control, and a more open sense of space.\u003c\/p\u003e\n\n\u003cp\u003eThe result is a headphone tuned for a spacious, detailed, and powerful listening experience. Artemis is built for music that needs room to move, whether that means the scale of electronic music, the layering of orchestral recordings, the texture of vocals, or the punch and energy of modern mixes.\u003c\/p\u003e\n\n\u003ch3\u003ePersonalized Listening with Audiodo\u003c\/h3\u003e\n\n\u003cp\u003eFoKus Artemis includes Audiodo Personal Sound, giving listeners a more tailored experience based on their own hearing profile. Instead of relying only on a fixed factory tuning, Artemis can adapt the listening experience to better match the way you hear.\u003c\/p\u003e\n\n\u003cp\u003eThat makes the headphone more personal without taking away from Noble’s core sound philosophy. You still get the scale, clarity, and refinement of the hybrid driver system, with added flexibility to make the presentation feel more natural to you.\u003c\/p\u003e\n\n\u003ch3\u003eWireless When You Want It, Wired When You Need It\u003c\/h3\u003e\n\n\u003cp\u003eArtemis is built on the Qualcomm QCC3095 platform with Bluetooth 5.4 for stable modern wireless performance. Codec support includes SBC, AAC, aptX, aptX HD, and LDAC, giving you strong compatibility across phones, tablets, laptops, and high-resolution wireless sources.\u003c\/p\u003e\n\n\u003cp\u003eFor listeners who want a direct connection, Artemis also supports USB audio and 3.5mm wired audio through the included USB-C to 3.5mm cable. That flexibility makes it easy to use Artemis across more devices, whether you are listening wirelessly from your phone, plugging into a laptop over USB-C, or using a wired connection when Bluetooth is not the right fit.\u003c\/p\u003e\n\n\u003ch3\u003eBuilt for Everyday Use\u003c\/h3\u003e\n\n\u003cp\u003eFoKus Artemis is a flagship headphone, but it is not built only for quiet rooms and perfect conditions. Active Noise Cancellation helps reduce outside distractions when you want to focus, while Transparency Mode lets outside sound back in when you need awareness. Multipoint connectivity makes it easier to move between devices, and the six-microphone design supports clearer voice pickup for calls and meetings.\u003c\/p\u003e\n\n\u003cp\u003eThe long battery life makes Artemis easy to use throughout the week. Playback is rated for more than 50 hours with ANC off and more than 35 hours with ANC on, while fast charging helps you get back to listening quickly. The 600mAh battery is also fully self-replaceable, giving Artemis a stronger long-term ownership story than most premium wireless headphones.\u003c\/p\u003e\n\n\u003ch3\u003eA Flagship Wireless Headphone with a Longer View\u003c\/h3\u003e\n\n\u003cp\u003eThe self-replaceable battery is one of Artemis’s most important design choices. Wireless headphones are often limited by battery lifespan, even when the acoustic design still has years of use left. By making the battery customer replaceable, Noble gives Artemis a more practical path for long-term ownership.\u003c\/p\u003e\n\n\u003cp\u003eThat fits the larger idea behind FoKus Artemis: a wireless headphone that feels premium now, but also makes sense beyond the first couple years of use. With hybrid drivers, premium codec support, USB and wired listening, app-based control, ANC, and a replaceable battery, Artemis is built to be more than a convenience headphone. It is Noble’s flagship wireless over-ear for listeners who care about sound, design, and longevity.\u003c\/p\u003e\n\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eFlagship wireless over-ear headphone from Noble Audio\u003c\/li\u003e\n  \u003cli\u003eHybrid three-driver configuration with dynamic driver, balanced armature, and planar driver\u003c\/li\u003e\n  \u003cli\u003eSpacious, detailed, and powerful sound designed for serious music listening\u003c\/li\u003e\n  \u003cli\u003eAudiodo Personal Sound for a more tailored listening experience\u003c\/li\u003e\n  \u003cli\u003eQualcomm QCC3095 wireless platform\u003c\/li\u003e\n  \u003cli\u003eBluetooth 5.4 connectivity\u003c\/li\u003e\n  \u003cli\u003eSBC, AAC, aptX, aptX HD, and LDAC codec support\u003c\/li\u003e\n  \u003cli\u003eActive Noise Cancellation for reducing outside noise\u003c\/li\u003e\n  \u003cli\u003eTransparency Mode for environmental awareness\u003c\/li\u003e\n  \u003cli\u003eMultipoint connectivity for switching between devices\u003c\/li\u003e\n  \u003cli\u003eUSB audio support\u003c\/li\u003e\n  \u003cli\u003e3.5mm wired audio support via included USB-C to 3.5mm cable\u003c\/li\u003e\n  \u003cli\u003eSix-microphone design\u003c\/li\u003e\n  \u003cli\u003eNoble FoKus app support with EQ, OTA updates, and multi-language support\u003c\/li\u003e\n  \u003cli\u003e600mAh full self-replaceable battery\u003c\/li\u003e\n  \u003cli\u003eMore than 50 hours of playback with ANC off\u003c\/li\u003e\n  \u003cli\u003eMore than 35 hours of playback with ANC on\u003c\/li\u003e\n  \u003cli\u003eFast charging with full charge in under 1.5 hours\u003c\/li\u003e\n  \u003cli\u003eIP52 water resistance\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width:100%; border-collapse:collapse;\"\u003e\n  \u003ctbody\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eProduct Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eWireless over-ear headphone\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Configuration\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eHybrid three-driver system\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDrivers\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eDynamic driver + balanced armature + planar driver\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eFrequency Response\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e10Hz to 40kHz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eRated Power\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e20mW\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eImpedance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e32Ω\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eSensitivity\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e99dB +\/- 3dB at 1kHz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eChipset\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eQualcomm QCC3095\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eBluetooth\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eBluetooth 5.4\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eBluetooth Profiles\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eA2DP, AVRCP, HFP, HSP, SPP\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eSupported Codecs\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eSBC, AAC, aptX, aptX HD, LDAC\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eWireless Range\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e10m\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eNoise Control\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eActive Noise Cancellation and Transparency Mode\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMicrophones\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eSix-microphone design\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eBattery\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e600mAh full self-replaceable battery\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePlayback\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e35+ hours with ANC on, 50+ hours with ANC off\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eCharging Time\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eUnder 1.5 hours\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eApp Support\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eNoble FoKus app with EQ, OTA updates, and multi-language support\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eWater Resistance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eIP52\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMSRP\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e$899 USD\u003c\/td\u003e\n    \u003c\/tr\u003e\n  \u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Noble Audio","offers":[{"title":"Default Title","offer_id":49006093238343,"sku":"OHFS03-OPEN","price":799.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/FoKusArtemis-196.jpg?v=1780509925","url":"https:\/\/headphones.com\/products\/noble-audio-fokus-artemis-wireless-headphones-open-box","provider":"Headphones.com","version":"1.0","type":"link"}
