{"product_id":"noble-audio-fokus-apollo-wireless-headphones-open-box-clearance","title":"Noble Audio FoKus Apollo Wireless Headphones - Open Box - Clearance","description":"\u003cp\u003e\u003cmeta charset=\"utf-8\"\u003e\u003cstrong\u003eOpen-box items in C condition are open box items that are not in like-new condition. They may show signs of wear, have packaging that is imperfect and be missing accessories. Clearance items are sold as is without a warranty guarantee and no returns. \u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eIntroducing the Noble Audio FoKus Apollo, a revolutionary step into the world of wireless over-ear headphones. As Noble Audio's first over-ear model, the FoKus Apollo features the world's first patented hybrid dual driver arrangement, combining a 40mm dynamic driver with a 14.5mm planar magnetic driver. This unique combination delivers an unparalleled audio experience, blending powerful bass with delicate, crystal-clear mid and high frequencies.\u003c\/p\u003e\n\u003ch3\u003eAdvanced Wireless Technology\u003c\/h3\u003e\n\u003cp\u003eThe Noble Audio FoKus Apollo is equipped with the latest Bluetooth 5.3 technology, providing a seamless and stable connection. With support for multipoint connection, you can easily switch between devices without any interruptions. Enjoy lossless audio quality with a range of supported codecs, including LDAC, AAC, aptX, and aptX HD, ensuring that your music sounds its best no matter what device you're using.\u003c\/p\u003e\n\u003ch3\u003eUnmatched Battery Life\u003c\/h3\u003e\n\u003cp\u003eExperience the freedom of extended listening with the best battery life on the market. The FoKus Apollo offers up to 80 hours of playtime with ANC off at 50% volume and up to 60 hours with ANC on. Whether you're on a long flight or a busy day at work, these headphones are designed to keep up with your lifestyle, providing uninterrupted high-quality sound.\u003c\/p\u003e\n\u003ch3\u003eSuperior Build and Comfort\u003c\/h3\u003e\n\u003cp\u003eCrafted with premium materials, the FoKus Apollo features an anodized aluminum frame and memory foam Korean Protein leather earpads, ensuring durability and comfort. The earpads are replaceable, extending the lifespan of your headphones and maintaining a comfortable fit. The Alcantara headband adds a touch of luxury, making the FoKus Apollo a pleasure to wear for extended periods.\u003c\/p\u003e\n\u003ch3\u003eAdvanced Noise Cancellation\u003c\/h3\u003e\n\u003cp\u003eThe FoKus Apollo utilizes hybrid ANC technology with the QCC3084 chip, incorporating three microphones per side for superior noise reduction up to -35dB. This advanced ANC system uses both feedforward and feedback microphones to cancel out ambient noise more effectively, allowing you to immerse yourself in your music without distractions. Additionally, the transparency mode lets you stay aware of your surroundings when needed.\u003c\/p\u003e\n\u003ch3\u003eVersatile and Practical Features\u003c\/h3\u003e\n\u003cp\u003eDesigned for both office and gaming use, the FoKus Apollo comes with a detachable boom mic featuring a mute switch for clear communication. The six integrated microphones ensure exceptional voice clarity, whether you're on a call or recording a podcast. With multiple wired connection options, including USB-C, 3.5mm auxiliary cable, and a wired airplane adapter, you have the flexibility to connect to a wide range of devices.\u003c\/p\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003cth\u003eSpecification\u003c\/th\u003e\n\u003cth\u003eDetails\u003c\/th\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDriver Arrangement\u003c\/td\u003e\n\u003ctd\u003eHybrid Dual Driver: 40mm dynamic driver + 14.5mm planar magnetic driver\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBluetooth Version\u003c\/td\u003e\n\u003ctd\u003e5.3\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eMultipoint Connection\u003c\/td\u003e\n\u003ctd\u003eYes\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSupported Codecs\u003c\/td\u003e\n\u003ctd\u003eLDAC, AAC, aptX, aptX HD\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBattery Life (No ANC)\u003c\/td\u003e\n\u003ctd\u003eUp to 80 hours (50% volume)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eBattery Life (With ANC)\u003c\/td\u003e\n\u003ctd\u003eUp to 60 hours (50% volume)\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eActive Noise Cancellation\u003c\/td\u003e\n\u003ctd\u003e-20dB to -35dB reduction\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eChip\u003c\/td\u003e\n\u003ctd\u003eQCC3084 with Ultra-Low-Power ANC\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrame Material\u003c\/td\u003e\n\u003ctd\u003eAnodized Aluminum\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eEarpads\u003c\/td\u003e\n\u003ctd\u003eMemory foam Korean Protein leather, replaceable\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eNumber of Microphones\u003c\/td\u003e\n\u003ctd\u003e6\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDetachable Boom Mic\u003c\/td\u003e\n\u003ctd\u003eIncluded, with mute switch\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eAdditional Features\u003c\/td\u003e\n\u003ctd\u003eTransparency Mode, Noble FoKus App Compatibility\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003ch3\u003eWhat's Included\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eNoble Audio FoKus Apollo Wireless Headphones with ANC\u003c\/li\u003e\n\u003cli\u003eEVA Carrying Case\u003c\/li\u003e\n\u003cli\u003e3.5mm Auxiliary Cable\u003c\/li\u003e\n\u003cli\u003eUSB-C Cable\u003c\/li\u003e\n\u003cli\u003eTwo-Prong Airline Adapter\u003c\/li\u003e\n\u003cli\u003e6.3mm Adapter for Headphone Amps\u003c\/li\u003e\n\u003cli\u003eDetachable Boom Mic\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eExperience the future of wireless audio with the Noble Audio FoKus Apollo, available now at Headphones.com. Whether you're an audiophile, a professional, or a gamer, these headphones offer the perfect blend of advanced technology, superior sound quality, and luxurious comfort.\u003c\/p\u003e","brand":"Noble Audio","offers":[{"title":"Like-New","offer_id":42981520736327,"sku":"OHFS01-OPEN-C-1","price":499.0,"currency_code":"USD","in_stock":true},{"title":"Missing outer sleeve - has packaging + all accessories","offer_id":42981520769095,"sku":"OHFS01-OPEN-C-2","price":399.0,"currency_code":"USD","in_stock":true},{"title":"No exterior packaging - has carry case + all accessories","offer_id":42981520801863,"sku":"OHFS01-OPEN-C-3","price":399.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/NobleAudioFokusApollo41024x1024.jpg?v=1723092323","url":"https:\/\/headphones.com\/products\/noble-audio-fokus-apollo-wireless-headphones-open-box-clearance","provider":"Headphones.com","version":"1.0","type":"link"}
