{"product_id":"meze-audio-109-pro-headphones-b-stock","title":"Meze Audio 109 PRO Headphones - B-Stock","description":"\u003ch3\u003eMeze Audio 109 PRO Headphones - B-Stock\u003c\/h3\u003e\n\u003cp\u003eSave $200 on the beloved Meze Audio 109 Pro with our B-Stock sale. The B-Stock 109 Pro can have minor cosmetic blemishes on the product, packaging or accessories but is guaranteed to be perfect working condition. \u003c\/p\u003e\n\u003cp\u003eThe 109 PRO sits at the top of Meze's open-back dynamic line, above the 105 SILVA and 105 AER. It is a headphone for people who listen for pleasure before analysis: full bass, an airy top end, and a frame light enough to forget about over a long evening. A B-Stock unit makes sense if you care more about how a headphone sounds and feels than about a flawless finish.\u003c\/p\u003e\n\u003ch3\u003eWhat B-Stock Means\u003c\/h3\u003e\n\u003cp\u003eB-Stock is Meze's own grade. Meze describes these as new units with minor cosmetic imperfections. They are new headphones, and the flaw is in how one looks, not in how it plays.\u003c\/p\u003e\n\u003cp\u003eMeze does not list the mark on each unit, so we cannot say in advance where yours will be or how visible it is. The photos on this page show a first-quality 109 PRO. Walnut is a natural material, so grain and color already differ from pair to pair, and a B-Stock unit will also carry a small imperfection that these photos do not show. If a perfect finish matters to you, the first-quality \u003ca href=\"\/products\/meze-audio-109-pro-headphones\" title=\"Meze Audio 109 PRO Headphones\" rel=\"noopener\" target=\"_blank\"\u003eMeze Audio 109 PRO\u003c\/a\u003e is the one to buy.\u003c\/p\u003e\n\u003cp\u003eQuantities are limited. Meze released a small number of B-Stock units, and once they are sold this listing ends.\u003c\/p\u003e\n\u003ch3\u003eHow the 109 PRO Sounds\u003c\/h3\u003e\n\u003cp\u003eThe 109 PRO is tuned to be enjoyed. Bass reaches deep for an open-back dynamic headphone and carries real body and punch, while the upper treble adds sparkle and air above 10kHz, which gives cymbals, strings, and room sound a lift. Our reviewers describe the result as U-shaped: extra at both ends, with the midrange set back a little.\u003c\/p\u003e\n\u003cp\u003eAndrew Park (Resolve) put the 109 PRO on his list of the \u003ca href=\"\/blogs\/buying-guides\/best-open-back-headphones\" title=\"Best Open-Back Headphones buying guide by Andrew Park\" rel=\"noopener\" target=\"_blank\"\u003ebest open-back headphones\u003c\/a\u003e, calling it \"a legitimate all-rounder worth considering\" and describing its soundstage as spacious and open. It was also named Best Headphones 2023-2024 in the EISA Awards.\u003c\/p\u003e\n\u003cp\u003eThat tuning is not for everyone. Our \u003ca href=\"\/blogs\/buying-guides\/headphones-com-open-back-headphone-buying-guide-500-1000\" title=\"Headphones.com Open-Back Headphone Buying Guide: $500 to $1,000\" rel=\"noopener\" target=\"_blank\"\u003eopen-back buying guide for $500 to $1,000\u003c\/a\u003e lists the 109 PRO for its bass extension, comfort, and build, and it also notes that the treble can come across as gritty for some listeners and that the headphone is not tuned for neutrality. If you are sensitive to bright treble, or you want a flat reference sound for mixing, the 109 PRO is not the right fit. If you want music to sound vivid and full, it is very easy to like.\u003c\/p\u003e\n\u003ch3\u003eThe 50mm Driver\u003c\/h3\u003e\n\u003cp\u003eMeze built a new 50mm dynamic driver for the 109 PRO and put the effort into materials. The dome is a cellulose composite reinforced with carbon fiber, chosen because it is light and helps reduce the resonances that cause distortion. Around it sits the torus, the flexible ring that lets the dome move, made from a polymer just 22 microns thick with a beryllium coating that adds stiffness without adding much weight.\u003c\/p\u003e\n\u003cp\u003eA copper-zinc alloy stabilizer around the membrane absorbs leftover vibration, and Meze rates distortion below 0.1% at 1kHz. In plain terms, a light and stiff driver starts and stops quickly, which is where the 109 PRO's sense of detail comes from. The rated frequency range runs from 5Hz to 30kHz.\u003c\/p\u003e\n\u003ch3\u003eOpen-Back: What That Means at Home\u003c\/h3\u003e\n\u003cp\u003eOpen-back means the ear cups are open to the room. Inside each walnut cup, a spider-shaped frame and an acoustically transparent grille leave the driver exposed on both sides, which is what gives the 109 PRO its spacious sound. The trade is isolation: people near you will hear your music, and you will hear them. The 109 PRO belongs in a quiet room, not on a commute or in a shared office.\u003c\/p\u003e\n\u003ch3\u003eComfort and Build\u003c\/h3\u003e\n\u003cp\u003eThe 109 PRO weighs 375g without its cable. A self-adjusting headband spreads that weight evenly across your head, and the velour ear pads are softer and more breathable than leather, so your ears stay cool through a long session. Andrew Park called it one of the most comfortable headphones available.\u003c\/p\u003e\n\u003cp\u003eThe frame combines black walnut, cast zinc, manganese steel, and vegan leather. Meze designs the 109 PRO to be taken apart and serviced, so cables, ear cups, and other parts can be replaced as they wear and the headphone can stay in use for years.\u003c\/p\u003e\n\u003ch3\u003eEasy to Drive\u003c\/h3\u003e\n\u003cp\u003eAt 40 ohms and 112dB of sensitivity, the 109 PRO plays loudly from almost anything with a headphone jack: a laptop, a phone adapter, a portable DAC. An amplifier is not required. It is just as much at home on a desktop DAC and amplifier if you already own one.\u003c\/p\u003e\n\u003cp\u003eTwo cables are included, 1.5m for a desk and 3m for a listening chair. Both end in a 3.5mm plug, and a 6.3mm adapter covers full-size amplifier jacks. The cable connects to each ear cup with its own 3.5mm plug, so a worn or damaged cable is a simple swap.\u003c\/p\u003e\n\u003ch3\u003eHow the 109 PRO B-Stock Compares\u003c\/h3\u003e\n\u003cp\u003eAgainst a first-quality 109 PRO at $799, a B-Stock unit is the same headphone with a cosmetic mark and a lower price. That is the whole difference.\u003c\/p\u003e\n\u003cp\u003eWithin Meze's own line, the \u003ca href=\"\/products\/meze-audio-105-silva-headphones\" title=\"Meze Audio 105 SILVA Headphones\" rel=\"noopener\" target=\"_blank\"\u003eMeze Audio 105 SILVA\u003c\/a\u003e is the smoother choice. Our reviewers found its treble calmer than the 109 PRO's, at the cost of a little of the detail and crispness that make the 109 PRO exciting.\u003c\/p\u003e\n\u003cp\u003eOutside the brand, the planar magnetic \u003ca href=\"\/products\/hifiman-arya-headphones-stealth-magnets-edition\" title=\"Hifiman Arya Stealth Magnets Edition Headphones\" rel=\"noopener\" target=\"_blank\"\u003eHifiman Arya Stealth\u003c\/a\u003e is the natural alternative. Our buying guide describes the Arya Stealth as extremely open and spacious. The same guide recommends the 109 PRO to listeners who want a healthy helping of bass without giving up clarity or comfort.\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eB-Stock unit: a new Meze Audio 109 PRO with a minor cosmetic imperfection\u003c\/li\u003e\n\u003cli\u003eOpen-back, over-ear dynamic headphone\u003c\/li\u003e\n\u003cli\u003e50mm dynamic driver developed for the 109 PRO\u003c\/li\u003e\n\u003cli\u003eCarbon fiber-reinforced cellulose composite dome\u003c\/li\u003e\n\u003cli\u003eBeryllium-coated polymer torus, 22 microns thick\u003c\/li\u003e\n\u003cli\u003eCopper-zinc alloy stabilizer to absorb vibration\u003c\/li\u003e\n\u003cli\u003eCNC-machined aluminum driver frame with neodymium magnet\u003c\/li\u003e\n\u003cli\u003eBlack walnut ear cups with an acoustically transparent grille\u003c\/li\u003e\n\u003cli\u003eSelf-adjusting headband for even pressure on any head shape\u003c\/li\u003e\n\u003cli\u003eFrame of black walnut, cast zinc, manganese steel, and vegan leather\u003c\/li\u003e\n\u003cli\u003eBreathable velour ear pads\u003c\/li\u003e\n\u003cli\u003e375g without cable\u003c\/li\u003e\n\u003cli\u003e40 ohms and 112dB SPL\/mW: runs from portable and desktop sources\u003c\/li\u003e\n\u003cli\u003e1.5m and 3m cables with 3.5mm plug, plus a 6.3mm adapter\u003c\/li\u003e\n\u003cli\u003eHard EVA carrying case included\u003c\/li\u003e\n\u003cli\u003eDesigned to be taken apart and serviced\u003c\/li\u003e\n\u003cli\u003eEISA Best Headphones 2023-2024\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003eCondition\u003c\/td\u003e\n\u003ctd\u003eB-Stock: new unit with a minor cosmetic imperfection\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eProduct Type\u003c\/td\u003e\n\u003ctd\u003eOpen-back, over-ear headphones\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDriver\u003c\/td\u003e\n\u003ctd\u003e50mm dynamic\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eDiaphragm\u003c\/td\u003e\n\u003ctd\u003eCarbon fiber-reinforced cellulose dome, beryllium-coated polymer torus\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eFrequency Range\u003c\/td\u003e\n\u003ctd\u003e5Hz - 30kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eImpedance\u003c\/td\u003e\n\u003ctd\u003e40 ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eSensitivity\u003c\/td\u003e\n\u003ctd\u003e112dB SPL\/mW at 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eTHD\u003c\/td\u003e\n\u003ctd\u003e\u0026lt;0.1% at 1kHz\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eEar Cups\u003c\/td\u003e\n\u003ctd\u003eBlack walnut wood\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eEar Pads\u003c\/td\u003e\n\u003ctd\u003eVelour\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eInput Connector\u003c\/td\u003e\n\u003ctd\u003eDual 3.5mm TS\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eCables\u003c\/td\u003e\n\u003ctd\u003e1.5m and 3m, 3.5mm plug\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003eWeight\u003c\/td\u003e\n\u003ctd\u003e375g (13 oz) without cable\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch3\u003eWhat's in the Box\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eMeze Audio 109 PRO headphones (B-Stock unit)\u003c\/li\u003e\n\u003cli\u003e1.5m soft TPE cable with 3.5mm plug\u003c\/li\u003e\n\u003cli\u003e3m soft TPE cable with 3.5mm plug\u003c\/li\u003e\n\u003cli\u003e6.3mm gold-plated adapter\u003c\/li\u003e\n\u003cli\u003eHard EVA carrying case\u003c\/li\u003e\n\u003cli\u003ePU leather pouch\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Meze","offers":[{"title":"Default Title","offer_id":50189211533383,"sku":"M-109P-BF","price":599.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/01-meze-audio-109-pro-b-stock.jpg?v=1795031412","url":"https:\/\/headphones.com\/products\/meze-audio-109-pro-headphones-b-stock","provider":"Headphones.com","version":"1.0","type":"link"}
