1 of 4
iBasso
iBasso DX240 Digital Audio Player (DAP) + Case - Open Box
Regular price $829
Sale price $829 Regular price $949.00
Wired, Wireless
iBasso
Regular price $829
iBasso DX240 DAP, black and green models | Headphones.com
The DX240 is a reference digital audio player (DAP) that houses dual system controllers along with dual batteries.
The 5.0inch IPS screen is sharp and vibrant with an HD resolution of 1080x1920.
A feature of the DX series is the replaceable AMP card design. AMP cards provide for more variety, personalization, and enjoyment of your music. You can change output port configuration, circuit design, play time, and much more. The DX240 music player features the Octa-Core Qualcomm Snapdragon 660 mobile platform, 5th Gen Mango OS + Android 9.0 OS, 4GB of RAM, 64GB internal storage with external expansion option, and the ESS flagship ES9038Pro DAC Chip.
iBasso DX240 DAP, closeup of music app | Headphones.com
Main Features
  • ESS flagship ES9038Pro DAC Chip.
  • Bit for Bit playback with support up to 32bit/768kHz.
  • Support of Native DSD up to 512x.
  • Sharp 5.0″ IPS full screen (1080*1920), with On-Cell capacitive touch panel.
  • Support of QC3.0 and PD3.0 quick charge.
  • In-house developed FPGA-Master as the audio system controller, synchronizing and generating the signal to all audio clocks.
  • 2 NDK ultra-low phase noise Femtosecond oscillators.
  • 14nm Octa-Core Qualcomm Snapdragon 660 SoC.
  • 4GB LPDDR4X + 64GB ROM.
  • USB digital output up to PCM 32bit/384kHz, Native DSD256, and DoP DSD128.
  • Mini coaxial output that supports up to 24bit/384kHz and DoP DSD128.
  • USB DAC function that supports up to 32bit/384kHz and DoP DSD128 input.
  • Support of 2.4GHz and 5GHz WiFi and Bluetooth 5.0.
  • Support of SDHC and SDXC Micro SD cards up to 2TB.
  • Support of USB 3.1 Super speed transfer.
  • 3 gain settings for hardware control.
  • 100 step volume control.
  • Patented replaceable AMP card design, compatible with AMP1 through AMP8.
  • Audio Formats Supported: MQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, and DXD.
  • Support for M3U playlists.
  • 3.8V 4400mAh Li-Polymer battery.
Contents
The DX240 DAP package includes:
  • DX240 player
  • Clear TPU protection case
  • Coaxial cable
  • Balanced burn-in cable
  • USB-C cable
  • Screen protector
  • Warranty card
  • Quick start guide
iBasso DX240 DAP, closeup of inputs | Headphones.com
Specifications
2.5mm Balanced Ouput (TRRS)
Maximum output level
6.2Vrms
Output Power
878mW@32ohm, 128mW@300ohm
Frequency Response
10Hz~45kHz +/-0.1dB
S/N
125dB
Dynamic Range
125dB
THD+N
-114dB (3Vrms, no load), -114dB (3Vrms, 32ohm load)
Crosstalk
-119dB
Output impedance
0.57ohm
3.5mm Single Ended Phone Out
3.1Vrms
Output Power
281mW@32ohm, 32mW@300ohm
Frequency Response
10Hz~45kHz +/-0.1dB
S/N
123dB
Dynamic Range
123dB
THD+N
-110dB (1.8Vrms, no load, -109dB (1.8Vrms, 32ohm load)
Crosstalk
-117dB
Output impedance
0.38ohm
3.5mm Single Ended Line Out
3Vrms
Frequency Response
10Hz~45kHz +/-0.1dB
S/N
122dB
Dynamic Range
-122dB
THD+N
-110dB (1.8Vrms, no load)
Crosstalk
-116dB
Average Play Time
11hours (The play time varies with different resolutions, volume used and headphone /IEMloads.)
iBasso DX240 DAP, unit in hand showing back side | Headphones.com
