iBasso DX170 Digital Audio Player
Amplifier type
Wired, Wireless
Portability
365-day returns
iBasso
The iBasso DX170 Digital Audio Player (DAP) is an upgrade over it's best in class budget predecessor, the DX160. Available in Black, Blue or Grey, the DX170 is the perfect travel companion for any audiophile looking to take their listening on the go. Pair it with the Moondrop Blessing 2 or the Dunu SA6 for auditory bliss!
Highlights
- FPGA-Master + Dual fs NDK
- Dual CS43131
- RK3566 SOC
- 5.0inch 1080P Flil Screen
- Android 11 OS
- DNR: 130dB THD+N 0.00022%
- Coaxial Digital Output
- Bluetooth LDAC aptX Output
- USB DAC
- 3 Protocol Quick Charge
- USB Digital IN & OUT
- USB DAC Capable
- 2G RAM 32G ROM
- Native DSD256
- MQA 8X
- PCM 32bit/384kHz
- Up to 11 Hours Playtime
FPGA-MASTER + DUAL FEMTOSECOND NDK OSCILLATORS
The DX170 utilizes the FPGA-Master technology developed by iBasso. The FPGA-Master, as the audio system controller, directly requests audio data from the SoC, and plays a major role in signal reproduction and maintaining signal integrity. It synchronizes and generates all audio clocks at the same time utilizing two NDK femtosecond oscillators to achieve a fully synchronized single clock source. The FPGA and NDK oscillators also reduce jitter to an extremely low level, building a clean digital audio signal.
CIRRUS CS43131 X 2
Dual Cirrus Logic flagship DAC chips, CS43131 are utilized. The chip dynamic range is 130dB and a THD+N -115dB, as established by CS. With an exclusive OPAMP+BUF amplification after the CS43131, the DX170 brings forth the strengths of CS43131.
Regardless of if you're using the 3.5mm single-ended or 4.4mm balanced output, with diligent tuning and adjustment, the DX170 not only retains the transparency and exquisiteness of CS43131, but also enhances the musicality and realism of the music.
THE NEW GENERATION RK SOC
With the advanced process technology of the RK3566, the system response is significantly improved. The AnTuTu score now reaches 100,000, far exceeding the Qualcomm 430/425 platform commonly used by players of the same price range. The user experience is greatly improved and enhanced.
SHARP 1080P FULL SCREEN
16.7 million colors, 445ppi retina display, 480cd/m2 screen brightness, On Call capacitive touch screen, 2.5D Corning glass panel, 95% light transmission and sRGB color gamut.
ANDROID 11 OS
System Wide SRC Bypassed
The Android 11 system is debuted in the mid-range player, with a more smooth and intuitive user interface. Users can install APKs freely and enjoy the convenience of online streaming.
The DX170 inherits the system architecture of iBasso players, enjoying a system wide "Non-SRC" Android 11 OS.
A BLACKER BACKGROUND HELPS WONDERFUL SOUND EMERGE
Very Low Noise Floor Helps Ensure Musical Enjoyment
Just like being out on a quiet night, you can focus on the world of the music and touch every note. Even in the face of high sensitivity IEMs, the background noise is imperceptible.
ENJOY YOUR MUSIC WITH COLOR AND FASHION
CNC engraved aluminum frame with Black, Grey, or Blue Anodized finishes. With an up-to-date 5 inch 1080p full screen and a curved frosted glass + etched back cover, the visual enjoyment during use is enhanced.
MQA 8X
The DX170 includes MQA technology which enables you to playback MQA audio files and streams, enjoying the sound of the original master recording.
FEATURES
- Coaxial Output: Coaxial output is driven by FPGA-Master, supports PCM 24bit/384kHz, DoP DSD128x
- 5G WiFi and Bluetooth 5.0: Supports WiFi6, LDAC, and aptX Bluetooth ouput.
- Stronger Internal Shielding: Customized silicon steel alloy shielding cover not only shields the electric field, but also shields the magnetic field.
- Allows for USB DAC Mode: PCD 32bit/384kHz, DoP DSD128x
- 3 Quick Charge Protocols: Support of QC3.0, PD2.0, & MTK PE Plus Quick Charge. Full charge in 1.5 hours, enjoys 11 hours playtime.
