{"product_id":"hifiman-he6-remastered-headphones","title":"Hifiman HE6 Remastered Headphones","description":"\u003cp\u003eThe HIFIMAN HE6 Remastered brings back one of the most respected headphones in HIFIMAN history. Originally released as a flagship, the HE6 earned its reputation with a combination of speed, control, dynamic range, and raw resolving power that still gives it a special place among planar magnetic headphones. The Remastered edition keeps the character that made the original a legend, while updating the build for a more comfortable modern fit.\u003c\/p\u003e\n\n\u003cp\u003eThis is not a soft reboot or a casual lifestyle refresh. HE6 Remastered is built for listeners who want the classic HE6 experience: open-back planar speed, explosive dynamics, deep technical performance, and a presentation that rewards serious amplification. It preserves the original HE6’s gold-sputtered diaphragm and restores key early-edition construction elements, while adding HIFIMAN’s new Gen 2 ergonomic headband to reduce weight and improve long-session comfort.\u003c\/p\u003e\n\n\u003ch3\u003eThe Return of a HIFIMAN Classic\u003c\/h3\u003e\n\n\u003cp\u003eThe original HE6 became famous because it sounded different from the typical high-end headphone. It was fast, open, powerful, and unusually revealing, with the kind of dynamic swing that made it feel closer to a speaker system than a conventional headphone. HE6 Remastered is designed to carry that spirit forward.\u003c\/p\u003e\n\n\u003cp\u003eIts tuning and driver architecture are made for listeners who care about nuance and scale. Small details come through clearly, but the bigger story is the way HE6 Remastered handles dynamic contrast. Quiet passages have texture and space. Loud moments hit with conviction. Bass, mids, and treble feel connected by speed rather than softened for easy listening.\u003c\/p\u003e\n\n\u003ch3\u003eGold-Sputtered Planar Magnetic Diaphragm\u003c\/h3\u003e\n\n\u003cp\u003eAt the center of HE6 Remastered is the original HE6’s gold-sputtered planar magnetic diaphragm. HIFIMAN’s nanometer-thickness diaphragm is exceptionally lightweight, allowing the driver to respond quickly to changes in the signal. That speed helps preserve transient detail, low distortion, and the wide dynamic expression that made the HE6 name so respected.\u003c\/p\u003e\n\n\u003cp\u003eThe Remastered edition also reissues the early-edition HE6 planar driver approach, including the brass protective mesh and external reinforcing ribs for the magnet structure. These details are part of what separates HE6 Remastered from later HE6 variants and help reconnect the new model with the original headphone’s design identity.\u003c\/p\u003e\n\n\u003ch3\u003eOpen-Back Scale and Planar Control\u003c\/h3\u003e\n\n\u003cp\u003eHE6 Remastered is an open-back planar magnetic headphone built for space, speed, and control. The open design gives recordings room to expand, while the planar driver provides the low distortion and diaphragm control that planar listeners expect. The result is a headphone that can sound wide, immediate, and intensely resolving when paired with the right amplifier.\u003c\/p\u003e\n\n\u003cp\u003eThis is a headphone for focused listening. It is not trying to be compact, wireless, or forgiving. It is built for a serious desktop chain, where its 50Ω impedance and low 83.5dB sensitivity can be properly supported. Give HE6 Remastered enough power, and it rewards the system with the kind of authority and openness that made the original famous.\u003c\/p\u003e\n\n\u003ch3\u003eA Lighter, More Comfortable Remaster\u003c\/h3\u003e\n\n\u003cp\u003eOne of the biggest practical updates is the new composite headband. HIFIMAN’s Gen 2 ergonomic headband reduces weight by roughly 20 to 30 grams compared with earlier construction while adding rotatable hinges for a more comfortable fit. At 522g, HE6 Remastered is still a substantial headphone, but the updated headband makes it easier to wear for longer sessions.\u003c\/p\u003e\n\n\u003cp\u003eThe design keeps the visual and structural language of the classic HE6 while making the Remastered version more approachable for today’s listeners. It feels like a proper continuation of the original rather than a replacement that forgets what made the HE6 matter.\u003c\/p\u003e\n\n\u003ch3\u003eBuilt for Serious Amplification\u003c\/h3\u003e\n\n\u003cp\u003eThe HE6 Remastered is not a headphone you buy for casual source matching. Its 83.5dB sensitivity makes amplification a major part of the experience. A strong desktop headphone amplifier or speaker-amp-style setup is the right direction for getting the most out of it.\u003c\/p\u003e\n\n\u003cp\u003eThat demanding nature is part of the HE6 story. This headphone is known for scaling with power and control. When properly driven, HE6 Remastered delivers the speed, bass grip, spaciousness, and dynamic range that made the original a benchmark for enthusiasts who wanted a planar headphone with real authority.\u003c\/p\u003e\n\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eRemastered version of HIFIMAN’s legendary former flagship HE6\u003c\/li\u003e\n  \u003cli\u003eOpen-back planar magnetic headphone design\u003c\/li\u003e\n  \u003cli\u003ePreserves the original HE6 gold-sputtered diaphragm\u003c\/li\u003e\n  \u003cli\u003eNanometer-thickness diaphragm for fast response and low distortion\u003c\/li\u003e\n  \u003cli\u003eEarly-edition HE6 planar driver reissued\u003c\/li\u003e\n  \u003cli\u003eBrass protective mesh and external reinforcing ribs for the magnet structure\u003c\/li\u003e\n  \u003cli\u003eExpansive dynamic range and high resolving power\u003c\/li\u003e\n  \u003cli\u003eNew Gen 2 ergonomic composite headband\u003c\/li\u003e\n  \u003cli\u003eRotatable hinges for improved wearing comfort\u003c\/li\u003e\n  \u003cli\u003eWeight reduced versus the early HE6 design\u003c\/li\u003e\n  \u003cli\u003e8Hz to 65kHz frequency response\u003c\/li\u003e\n  \u003cli\u003e50Ω impedance\u003c\/li\u003e\n  \u003cli\u003e83.5dB sensitivity\u003c\/li\u003e\n  \u003cli\u003eBest suited for powerful desktop amplification\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width:100%; border-collapse:collapse;\"\u003e\n  \u003ctbody\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eProduct Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eOpen-back planar magnetic headphone\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003ePlanar magnetic\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDiaphragm\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eGold-sputtered nanometer-thickness diaphragm\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDesign\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eOpen-back\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eFrequency Response\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e8Hz to 65kHz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eImpedance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e50Ω\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eSensitivity\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e83.5dB\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eWeight\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e522g \/ 1.15 lb\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eHeadband\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eGen 2 ergonomic composite headband with rotatable hinges\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePrice\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e$1,899\u003c\/td\u003e\n    \u003c\/tr\u003e\n  \u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Hifiman","offers":[{"title":"Default Title","offer_id":42938558971975,"sku":"HFM-HE6R","price":1899.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/HifimanHE6Remastered7.jpg?v=1783473303","url":"https:\/\/headphones.com\/products\/hifiman-he6-remastered-headphones","provider":"Headphones.com","version":"1.0","type":"link"}
