Hifiman Deva Pro Wireless Planar Magnetic Headphones
Cup style
Wearing style
Driver type
Wireless
Hifiman
Boasting HIFIMAN's advanced Stealth Magnet Design and Bluemini R2R with custom-created HIMALAYA DAC, HIFIMAN Deva Pro is one of the best Bluetooth planar magnetic headphones at its price range.
HIFIMAN'S NEO "SUPERNANO" DIAPHRAGM
The new NsD is 80% thinner than previous designs, resulting in fast response and detailed image with lush full range sonics.
ACOUSTICALLY INVISIBLE STEALTH MAGNET
Unlike the sound waves created by a conventional magnet, the special shape of Stealth Magnets enables the waves to pass through the magnets without generating interference.
HIFIMAN's advanced magnet design is acoustically transparent, dramatically reducing wave diffraction turbulence that degrades the integrity of the sound waves. The reduced distortion yields pure sonic output that is accurate and full-range.
BLUEMINI R2R
Small but mighty, the Bluemini R2R is the DEVA Pro's Bluetooth/USB companion module, and features the HIMALAYA DAC. The HIMALAYA DAC uses a non-oversampling design which produces high sampling rate. It's housed in an ultra-small form factor with low energy consumption
UPDATED INPUTS
The socket can accommodate both dual-sided unbalanced 3.5mm cable and a single-sided 3.5mm balanced cable (left socket). Bluemini R2R should be connected to the left socket.
SPECS
DEVA PRO SPECS
- Frequency Response: 20Hz - 20 kHz
- Impedance: 18Ω
- Sensitivity: 93.5dB
- Weight: 360g
BLUEMINI R2R SPECS
- Bluetooth version: Bluetooth 5.0
- Bluetooth chipset: Qualcomm QCC5124
- DAC HIFIMAN HIMALAYA
- Frequency Response: 20Hz - 20kHz
- Signal to noise ration: 114dB
- Battery life: 8 hours
- Net Weight: 25g
- Transmission codecs: LDAC, aptX-HD, aptX, AAC, SBC
