1 of 8
Focal
Focal Clear Mg Professional Headphones
Regular price $1,499
Sale price $1,499 Regular price
365-day returns
Focal
Focal Clear Pro Mg Dynamic Over-Ear Open-Back Stereo Headphones handcrafted in France | Available for purchase on Headphones.com
Introducing the brand new Focal Clear Mg Professional, an update on Focal's widely regarded Clear Pro open-back over-ear headphones.
Focal Clear Mg Professional over-ear open-back headphones for studio use handcrafted in France | Available on Headphones.com
Everything is designed for work comfort, as well as aesthetics. The design of the headband displays a constant curve and the weight of the headphones is distributed evenly across the head. The solid aluminium yoke is covered with a structured black paint, for sleek design and scratch resistance. Instead of the traditional vertically rotating mechanics, these have been moved within the headband for even greater comfort. This allows for excellent sealing, while the red & black blends classic and modern looks. The thermoformed carrying case shaped to fit the Clear Mg Professional, and with smaller dimensions, is woven in colours to match the headphones. Finally, two low-resistivity OFC 24 AWG copper cables are supplied.
The Focal Clear Mg Professional is a set of circum-aural open-back headphones. Their ‘M’-shaped Magnesium dome offers exceptional dynamics, combined with a capacity to reproduce the tiniest details across the full sound spectrum. In terms of mechanics, the design of the headband and yokes ensures that the headphones sit across the whole head, for optimal comfort. The new generation of perforated microfibre cushions result in an extremely open design. Clear Mg Professional headphones feature new honeycomb grilles. The opening of the external earcup is even wider, amplifying the sensation of spatialisation and the soundstage image. The internal ‘M’ grille follows the curves of the speaker driver as closely as possible, for an even more precise high frequency reproduction: you totally forget you’re wearing headphones, and instead enjoy the same listening sensation you’d get with the best monitors. The headphones assert themselves as the essential tool for the most demanding professionals, enabling you to make faster decisions thanks to these dynamics, and ensuring the transfer quality of the work performed.
Focal Clear Mg Professional Over-Ear open-back headphones highlights | Available on Headphones.com
Key points :
  • A brand new magnesium cone for even greater dynamics
  • A remarkable tonal balance across the full spectrum
  • The bass is articulated right down to the low frequencies
  • The level of detail in the high frequencies
  • Comfortable and ergonomic
  • Low impedance (55 Ohms)
  • 2 x OFC 24 AWG copper cables supplied: 1 x 16.5ft (5m)
  • spiral cable + 1 x 3.9ft (1.2m) cable, 1/8" (3.5mm) stereo
  • jack connector with 1/8" (3.5mm) jack – 1/4" (6.35mm)
  • jack adapter
  • Rigid carrying case supplied
Tech Specs
 Type
Circum-aural open-back headphones
Impedance
55 Ohms
Sensitivity
104dB SPL / 1mW @ 1kHz
THD
0,25 % @ 1kHz / 100dB SPL
Frequency response
5Hz – 28kHz
Speaker driver
15/8" (40mm) 'M'-shaped magnesium dome
Weight
(450g)
Cables supplied
3.94 feet (5m) asymmetric cable (1/4" - 6.35mm TRS jack) 3.94 feet (1.2m) asymmetric cable (1/8" - 3.5mm TRS jack) 1/8" (3.5mm) to 1/4" (6.35mm) stereo jack adapter
Spare earpads
2 x spare earpads supplied
Carrying case provided
97/8x91/2x43/4" (250x240x120mm)
