Focal Chora 826 Floorstanding Speakers (Pair)
Driver type
Portability
365-day returns
Focal
Highlights
- 1" TNF aluminum/magnesium inverted dome tweeter
- 6-1/2" Slatefiber midrange woofer
- dual 6-1/2" Slatefiber bass woofers
- Bass reflex design (front-firing port)
- Lean-back design ensures precise sound at the listening position
- Magnetic grille for woofers
- Vinyl finish
- Frequency response: 48-28,000 Hz (±3dB)
- Nominal impedance: 8 ohms
- Sensitivity: 91 dB
- Recommended amplifier power: 40-250 watts
THE FLAGSHIP MODEL
The Chora 826 bass-reflex loudspeaker is the embodiment of an accessible high-fidelity solution for a complete listening pleasure. Equipped with the exclusive Slatefiber cone developed and manufactured at the Focal site in France, the speaker drivers deliver balanced and precise midranges and perfectly articulated bass; leaving you to enjoy a big, full and generous sound. In addition, the presence of an aerodynamic front port eliminates distortion and gives more impact in the bass.
Its sleek, modern design combined with your choice of finish, and the tilted stand for a better sound image, make Chora 826 the flagship model of this line, ideal for large rooms.
SOFT AND PRECISE TREBLE
The surround linking the dome to its stand uses a memory foam material called Poron. This surround is directly derived from the Utopia’s famous Beryllium tweeter and reduces distortion by a third between 2,000Hz and 3,000Hz, the ear’s high-sensitivity range. The spatialisation and very low directionality of the inverted dome allow silky trebles to be heard from any point in your listening room.
PERFECTLY BALANCED SOUND
Slatefiber technology, exclusive to Focal, involves the use of recycled, non-woven carbon fibres applied as a sandwich between two layers of thermoplastic polymer. In their quest for perfection, Focal engineers have opted to use non-woven carbon fibres, all pointing in the same direction to achieve even greater rigidity and better damping.
Manufactured in the Focal workshops using an ultra-modern industrial tool, the “slate” effect of the cone provides better damping and rigidity, but also lightness – the three “essentials” of a good speaker driver.
In The Box
- Focal Chora 826 Floorstanding Loudspeaker (Pair)
- Base
- 8 x Rubber feet
- 8 x Spike feet
- 8 x Nuts
- 8 x Screws
- 8 x Washers
- Hex-key
- Grille
- User Manual
Specifications
Title | Description |
Power Range | 40-250 |
Frequency Response | 48-28k Hz |
Sensitivity | 91 dB |
Impedance (Ohms) | 8Ω |
Subwoofer Amp Power | N/A |
Height Per Speaker (inches) | 40-7/8 |
Width Per Speaker (inches) | 12 |
Depth Per Speaker (inches) | 15-7/8 |
Weight Per Speaker | 46.6 lbs |
