Focal Chora 816 Floorstanding Loudspeakers (Pair)
Driver type
Portability
365-day returns
Focal
Highlights
- Suitable for both hi-fi and Home Cinema configurations
- New speaker drivers with Slatefiber cone developed and manufactured in France by Focal
- Time Alignment thanks to the tilted stand: better soundstage
IDEAL FOR HOME CINEMA
The Chora 816 model is a 2.5-way bass-reflex floor-standing loudspeaker. Its woofer and mid-range/bass speaker driver, both equipped with the Slatefiber cone, work in perfect harmony for a voluptuous sound reproduction and a perfect bass impact. The sound finds its full dimension in your listening room, with a dynamic mid-range and remarkable power handling. A front port is placed below the loudspeaker to reduce distortion and, thanks to the tilt of the loudspeaker stand, Time Alignment provides a sound-stage focused on the listener.
Chora 816 is particularly well suited for Home Cinema listening and blends seamlessly into rooms of up to 323ft² (30m²).
SOFT AND PRECISE TREBLE
The surround linking the dome to its stand uses a memory foam material called Poron. This surround is directly derived from the Utopia’s famous Beryllium tweeter and reduces distortion by a third between 2,000Hz and 3,000Hz, the ear’s high-sensitivity range. The spatialisation and very low directionality of the inverted dome allow silky trebles to be heard from any point in your listening room.
PERFECTLY BALANCED SOUND
Slatefiber technology, exclusive to Focal, involves the use of recycled, non-woven carbon fibres applied as a sandwich between two layers of thermoplastic polymer. In their quest for perfection, Focal engineers have opted to use non-woven carbon fibres, all pointing in the same direction to achieve even greater rigidity and better damping.
Manufactured in the Focal workshops using an ultra-modern industrial tool, the “slate” effect of the cone provides better damping and rigidity, but also lightness – the three “essentials” of a good speaker driver.
A SLEEK, MODERN DESIGN
The Chora range boasts a modern design, all lifted onto a tilted stand for Time Alignment, which provides an optimal soundstage, more focused on the listener. The slate colour of the Slatefiber cone adds a final refined, authentic touch.
ON-TREND FINISHES
Chora is available in three finishes: Black, Light Wood and Dark Wood. On-trend colours that blend into different interiors and lend them a unique aesthetic signature.
Specifications
Title | Description |
Drivers | 61/2″ (16.5cm) Slatefiber Woofer 61/2″ (16.5cm) Slatefiber-Midbass 1″ (25mm) TNF Al/Mg inverted dome tweeter |
Sensitivity | (2,83V/1m) 89.5dB |
Frequency response | (±3dB) 50Hz-28kHz |
Low frequency point | (-6dB) 45Hz |
Nominal impedance | 8Ω |
Minimum impedance | 4Ω |
Recommended amplifier power | 40/200W |
Crossover frequency | 270Hz – 2700Hz |
Dimensions | (WxDxH) 117/8×159/32×409/32″ (30.3×38.8×102.3cm) |
Net weight (unit with grille, single speaker) | 40.8lbs (18.5kg) |
