Focal Chora 806 Bookshelf Speakers (Pair)
Driver type
Portability
365-day returns
Focal
The pictured Chora 806 Speaker Stand is not included with your purchase of the Chora 806 Bookshelf Speakers.
Highlights
- 1" TNF aluminum/magnesium inverted dome tweeter
- 6-1/2" Slatefiber mid/bass woofer
- Bass reflex design (front-firing port)
- Magnetic grilles for woofers
- Vinyl finish
- Frequency response: 58-28,000 Hz (±3dB)
- Nominal impedance: 8 ohms
- Sensitivity: 89 dB
- Recommended amplifier power: 25-120 watts
- 8-5/16"W x 17"H x 10-11/16"D
- Weight: 16.2 lbs. each
- Warranty: 5 years
COMPACT BUT POWERFUL
2-WAY BOOKSHELF LOUDSPEAKER
The Chora 806 loudspeaker showcases meticulous manufacturing and design. Let yourself be transported by the delightful, dynamic musical quality emitted by its 61/2” (16.5cm) bass/midrange speaker driver, equipped with the exclusive Focal Slatefiber cone. Alongside the TNF Aluminium/Magnesium tweeter with its silky treble, the “slate” colour of the speaker driver makes it an attractive yet high-performance solution.
Perfectly balanced, this bookshelf speaker is ideal for rooms of up to 215ft² (20m²).
SOFT AND PRECISE TREBLE
The surround linking the dome to its stand uses a memory foam material called Poron. This surround is directly derived from the Utopia’s famous Beryllium tweeter and reduces distortion by a third between 2,000Hz and 3,000Hz, the ear’s high-sensitivity range. The spatialization and very low directionality of the inverted dome allow silky trebles to be heard from any point in your listening room.
PERFECTLY BALANCED SOUND
Slatefiber technology, exclusive to Focal, involves the use of recycled, non-woven carbon fibres applied as a sandwich between two layers of thermoplastic polymer. In their quest for perfection, Focal engineers have opted to use non-woven carbon fibres, all pointing in the same direction to achieve even greater rigidity and better damping.
Manufactured in the Focal workshops in France using an ultra-modern industrial tool, the “slate” effect of the cone provides better damping and rigidity, but also lightness – the three “essentials” of a good speaker driver.
A SLEEK, MODERN DESIGN
The Chora range offers a modern design, the slate colour of the Slatefiber cone adding a final refined, authentic touch.
The stand (optional) is tilted for Time Alignment which provides an optimal soundstage, more focused on the listener.
ON-TREND FINISHES
Chora is available in three finishes: Black, Light Wood and Dark Wood. On-trend colours that blend into different interiors and lend them a unique aesthetic signature.
Specifications
Title | Description |
Type | 2-way bass-reflex bookshelf loudspeaker |
Drivers |
61/2" (16.5cm) Slatefiber Midbass 1" (25mm) TNF Al/Mg inverted dome tweeter |
Sensitivity (2,83V/1m) | 89dB |
Frequency response (±3 dB) | 58Hz-28kHz |
Low frequency point (-6 dB) | 49Hz |
Nominal impedance | 8Ω |
Minimum impedance | 4.6Ω |
Recommanded amplifier power | 25/120W |
Crossover frequency | 3.000Hz |
Dimensions (HxWxD) | 8-5/16"W x 17"H x 10-11/16"D |
