1 of 7
Final Audio
Final Audio UX3000 High Resolution Wireless Headphones with ANC
Regular price $149
Sale price $149 Regular price
Wireless, Wired
365-day returns
Sonic Club members get faster free shipping and earn 149 points on this purchase. Learn more
Final Audio
Regular price $149
Final UX3000
Wireless Noise Cancelling Headphones
UX3000 are the first wireless over-ear headphones from Final featuring hybrid active noise-cancelling technology.
While noise-cancelling requires electronically generated sounds to be played on top of your music, this puts stress on the drivers and generally degrades sound quality, requiring overly-boosted and muddy bass to correct.
Final Audio's engineering team in Japan has solved this challenge by designing a completely new driver that can achieve solid noise-cancelling performance and exceptional sound quality for this price point.
Premium Sound Quality
By fully utilizing its know-how in dynamic driver design technology and thoroughly optimizing the acoustic characteristics of the driver unit, Final delivers pleasing sound quality without the tiring sound characteristic typical for Bluetooth headphones at this price point. With its clear details together with soundstage, UX3000 achieves solid noise cancelling performance and impressive sound quality.
Hybrid Active Noise Cancelling
UX3000 features two microphones on each ear cup. One of the microphones listens to the outside world, and the other collects sound from the output of the driver unit. By analyzing the sound samples collected from both microphones and generating a highly accurate anti-noise signal, UX3000 is capable of removing constant ambient noises like airplane engines, train rumbles, and air conditioning hums with efficiency.
Hands-Free Calling
The built-in microphone makes it easy to make phone calls and join conference calls through your laptop or smartphone. The noise-cancelling function can remain on during phone calls, allowing you to hear the call clearly while blocking out ambient noise.
aptX Low Latency Support
In addition to the typical SBC and AAC Bluetooth codecs for music listening, the UX3000 also supports aptX™ Low Latency which delivers superb sound quality with exceptional connection stability on compatible devices. The UX3000 is compatible with a wide range of smartphone models such as iPhone and Android, with simple and easy pairing.
Multipoint Connection
UX3000 supports multipoint connection, which means you can connect two Bluetooth devices at the same time — listen to music on one, then quickly take incoming calls on the second.
Rechargeable Battery
A full charge offers up to 35 hours of music playback with noise cancelling off, and 25 hours with noise cancelling turned on. This varies depending on listening volume level. Easily recharge the battery using the universal USB-C connector.
Wired or Wireless
The UX3000 can easily be transformed into a pair of wired headphones by simply connecting the headphones to your audio source with the included audio cable, even if the battery has been depleted. This makes them well-suited for air travel and use with in-flight entertainment systems.
Foldable Design
The headphones can be folded, making them convenient and compact to carry. A soft carrying pouch is included to protect against scratches when travelling.
Premium Shibo Finish
Shibo is an old Japanese word meaning a wrinkle on the surface of paper or leather. This inspired the soft-textured coating of the UX3000 headphones, a beautiful surface that is superb at resisting dirt and fingerprints while sporting a subtle yet premium textured look.
Comfortable Fit
The earcup housing can be rotated up, down, left or right to fit various head shapes. The soft earpads are designed to prevent fatigue even after long periods of use.
In the Box
  • UX3000 Headphones
  • Carrying Pouch
  • USB Type C Charging Cable
  • Analog Audio Cable with 3.5mm Plug
