{"product_id":"ferrum-hypsos-linear-switching-hybrid-power-system-c-condition-clearance","title":"Ferrum HYPSOS Linear\/Switching Hybrid Power System - Open Box - C Condition - Clearance","description":"\u003ch3\u003e\n\u003cmeta charset=\"utf-8\"\u003e \u003cspan\u003eOpen-box Ferrum Hypsos in C condition are open box items that are \u003c\/span\u003e\u003cstrong\u003enot\u003c\/strong\u003e\u003cspan\u003e in like-new condition. They may show signs of wear, have packaging that is imperfect and be missing accessories. All clearance items are sold as is without a manufacturer's warranty guarantee and no returns.\u003c\/span\u003e\n\u003c\/h3\u003e\n\u003ch3\u003e\u003cimg alt=\"Ferrum Hypsos Linear \/ Switching hybrid power supply\" src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/Ferrum_Hypsos_lifestyle_1024x1024.jpg?v=1643834412\"\u003e\u003c\/h3\u003e\n\u003ch3\u003eAll it takes is a revolution\u003c\/h3\u003e\n\u003cp\u003eYou only get one chance to make a first impression. With this idea in mind, parent company HEM set out to conquer the world with Ferrum, a new brand, into which they distilled twenty years’ worth of experience of designing and manufacturing audio electronics. The building block of any great audio system is the power supply, so Ferrum first turned to the lowly power supply and made it better.\u003c\/p\u003e\n\u003ch3\u003eFerrum’s First Born\u003c\/h3\u003e\n\u003cp\u003eHYPSOS is a hybrid power system which combines the best features of both linear and switching power supplies. HYPSOS offers selectable power output allowing it to power a wide variety of devices, with a simple turn of a knob. This software-based operation is unique to HYPSOS and an industry first! Easy to use, HYPSOS also has an ingenious combination of existing power sensing techniques another distinctive feature. Adding a HYPSOS to any component will reveal previously obscured musical information with unrivalled detail. HYPSOS brings any component up to its utmost potential.\u003c\/p\u003e\n\u003ch3\u003eDoes your device run on DC? Hypsos can help!\u003c\/h3\u003e\n\u003cp\u003eWhether connected to a preamplifier, a D\/A converter, an outboard phono preamp, even a turntable or a network switch, HYPSOS will deliver a positive impact to any device. \u003c\/p\u003e\n\u003ch3\u003eHigh quality DC power cords \u003c\/h3\u003e\n\u003cp\u003eHYPSOS comes with your choice of a high quality DC power cable fitted with a 5.5x2.5mm or a 5.5x2.1mm DC plug. These are the most commonly used DC inlets. Other DC plugs sizes available by special request.\u003c\/p\u003e\n\u003cp\u003eHYPSOS defines a new category of hifi products. This is not just a simple power supply but an audio component in its own right - an equally important device as any other component in the audio system. HYPSOS offers a selection of unique features and even has the ability to receive software updates for future compatibility.\u003c\/p\u003e\n\u003cp\u003e \u003c\/p\u003e\n\u003csection data-element_type=\"section\" data-id=\"3027f30\" class=\"elementor-section elementor-inner-section elementor-element elementor-element-3027f30 elementor-section-boxed elementor-section-height-default elementor-section-height-default\"\u003e\n\u003cdiv class=\"elementor-container elementor-column-gap-default\"\u003e\n\u003cdiv class=\"elementor-row\"\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"34a63a3\" class=\"elementor-column elementor-col-100 elementor-inner-column elementor-element elementor-element-34a63a3\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"text-editor.default\" data-element_type=\"widget\" data-id=\"d6f1ad4\" class=\"elementor-element elementor-element-d6f1ad4 elementor-widget elementor-widget-text-editor\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"elementor-text-editor elementor-clearfix\"\u003e\n\u003ch2\u003eFeature Highlights\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003csection data-element_type=\"section\" data-id=\"681e92dd\" class=\"elementor-section elementor-inner-section elementor-element elementor-element-681e92dd elementor-section-boxed elementor-section-height-default elementor-section-height-default\"\u003e\n\u003cdiv class=\"elementor-container elementor-column-gap-default\"\u003e\n\u003cdiv class=\"elementor-row\"\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"23b03438\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-23b03438\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"4b133de8\" class=\"elementor-element elementor-element-4b133de8 elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eHybrid Power System\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eLinear\/switching hybrid design to get the advantages from both techniques - low ripple and noise as well as fast transient response and high efficiency.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"7905db5c\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-7905db5c\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"573a70af\" class=\"elementor-element elementor-element-573a70af elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eDistinct user levels\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eUsing pre-configured settings from the list of supported devices or setting custom parameters manually. Wide continuous output voltage range of 5-30V with up to 6A of current delivered to the load. HYPSOS is as universal a device as it gets.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003csection data-element_type=\"section\" data-id=\"22e0b75d\" class=\"elementor-section elementor-inner-section elementor-element elementor-element-22e0b75d elementor-section-boxed elementor-section-height-default elementor-section-height-default\"\u003e\n\u003cdiv class=\"elementor-container elementor-column-gap-default\"\u003e\n\u003cdiv class=\"elementor-row\"\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"17a0dd53\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-17a0dd53\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"62f856bf\" class=\"elementor-element elementor-element-62f856bf elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eSweet Spot Tuning (SST)\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003ePossibility to fine tune the output voltage for the best sound. The voltage level can be safely adjusted on the fly to allow easy comparison testing.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"75e40fa5\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-75e40fa5\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"6f5fc34b\" class=\"elementor-element elementor-element-6f5fc34b elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003e4T Sensing Design (4TSD)\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eEnsuring the exact voltage level precisely at the point of the powered device DC input terminal - special cable design and feedback to ensure flat voltage at every moment. This technique eliminates the harmful effects of the cable's resistance effectively improving transient response.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003csection data-element_type=\"section\" data-id=\"d7489f1\" class=\"elementor-section elementor-inner-section elementor-element elementor-element-d7489f1 elementor-section-boxed elementor-section-height-default elementor-section-height-default\"\u003e\n\u003cdiv class=\"elementor-container elementor-column-gap-default\"\u003e\n\u003cdiv class=\"elementor-row\"\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"1fc0f8e\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-1fc0f8e\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"c510f61\" class=\"elementor-element elementor-element-c510f61 elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eAdvanced Automation\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eCompatibility with Apple TV remote, Trigger in\/out connector; possibility to automate power-up of the devices with standby mode even without dedicated trigger connection.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"b0accad\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-b0accad\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"2e919b1\" class=\"elementor-element elementor-element-2e919b1 elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eExtremely safe to use\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eAutomatic Transformer Voltage Adjust (ATVA), Electronic Output Voltage Polarity Switch and overvoltage, current limit and short protection. Settings lock to prevent accidental change of the parameters.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003csection data-element_type=\"section\" data-id=\"317c9af\" class=\"elementor-section elementor-inner-section elementor-element elementor-element-317c9af elementor-section-boxed elementor-section-height-default elementor-section-height-default\"\u003e\n\u003cdiv class=\"elementor-container elementor-column-gap-default\"\u003e\n\u003cdiv class=\"elementor-row\"\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"00e31f8\" class=\"elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-00e31f8\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"1a47065\" class=\"elementor-element elementor-element-1a47065 elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\u003cspan\u003eDetailed and revealing yet unfatiguing sound\u003c\/span\u003e\u003c\/h4\u003e\n\u003cp class=\"elementor-icon-box-description\"\u003eMakes your current audio setup perform to its potential. Tweak the sound modifying the voltage level on the fly and use the preferred combination of the 4-Terminal Sensing and Spread Spectrum Mode settings.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv data-element_type=\"column\" data-id=\"f4e677d\" data-column-clickable-blank=\"_self\" data-column-clickable=\"https:\/\/ferrum.audio\/compatibility-list\/\" class=\"make-column-clickable-elementor elementor-column elementor-col-50 elementor-inner-column elementor-element elementor-element-f4e677d\"\u003e\n\u003cdiv class=\"elementor-column-wrap elementor-element-populated\"\u003e\n\u003cdiv class=\"elementor-widget-wrap\"\u003e\n\u003cdiv data-widget_type=\"themo-service-block.default\" data-settings='{\"_animation\":\"none\",\"_animation_delay\":150}' data-element_type=\"widget\" data-id=\"e897895\" class=\"elementor-element elementor-element-e897895 elementor-position-left elementor-view-default elementor-widget elementor-widget-themo-service-block\"\u003e\n\u003cdiv class=\"elementor-widget-container\"\u003e\n\u003cdiv class=\"th-service-block-w\"\u003e\n\u003cdiv class=\"elementor-icon-box-wrapper th-show-icon\"\u003e\n\u003cdiv class=\"elementor-icon-box-content\"\u003e\n\u003ch4 class=\"elementor-icon-box-title\"\u003e\n\u003cspan\u003e\u003c\/span\u003e\u003cbr\u003e\n\u003c\/h4\u003e\n\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003eWorks with a wide variety of components!\u003c\/strong\u003e\u003c\/span\u003e\u003c\/address\u003e\n\u003cul\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003eVoltage Compatibility: \u003c\/strong\u003e100-240Vac\/50-60Hz (Multi-Region)\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003ePower Inlet\u003c\/strong\u003e: Standard 15A IEC\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003ePower Filtration\u003c\/strong\u003e: Two-stage EMI filter\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eMains cable: \u003c\/strong\u003eUS (included)\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eDC Output Cable:\u003c\/strong\u003e 5×2.5mm DC plug \/ 5×2.1mm DC plug Custom cables made to order at additional cost\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cspan\u003e\u003cstrong\u003eOutput Voltage Range: \u003c\/strong\u003eFrom 5VDC to 30VDC\u003c\/span\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eMax Continuous Output Current: \u003c\/strong\u003e6A (up to 13.3VDC)\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eMax Continuous Output Current: \u003c\/strong\u003e80W (Voltages above 13.3VDC)\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eMaximum Impulse Current\u003c\/strong\u003e: 9A\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eMaximum Impulse Power\u003c\/strong\u003e: 270W @ 30V\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eDimensions (WDH): \u003c\/strong\u003e8.6x8.1x2.0 (not including knob, connectors etc)\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eWeight: \u003c\/strong\u003e6.2 Lbs\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003ePrimary Fuse: \u003c\/strong\u003e250V, 5x20mm, 3.15A, Slow Blow\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003cli\u003e\u003caddress\u003e\u003cspan\u003e\u003cstrong\u003e\u003c\/strong\u003e\u003cstrong\u003eSecondary winding fuse: \u003c\/strong\u003eLittefuse 154004T, 4A\u003c\/span\u003e\u003c\/address\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e","brand":"Ferrum Audio","offers":[{"title":"No Power Cable","offer_id":42484812283975,"sku":"FERRUM-HYPSOS-FPL-OPEN-C","price":695.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/products\/FerrumHypsos1024x1024.jpg?v=1707788337","url":"https:\/\/headphones.com\/products\/ferrum-hypsos-linear-switching-hybrid-power-system-c-condition-clearance","provider":"Headphones.com","version":"1.0","type":"link"}
