Feliks Audio Euforia Tube Headphone Amplifier
Amplifier type
Vacuum tube
Portability
Feliks Audio
The Feliks Audio Euforia is a flagship tube amplifier in anyway and if you are looking for euphonic bliss from your headphones, look no further than the Euforia from Feliks Audio. This beautifully handcrafted OTL, built around two 6SN7 and two 6AS7G tubes, delivers amazing dynamism, sound stage and level of details never heard of before in tube amplifiers, at the same time giving the unmistakably tube sound signature. Euforia's unique design allows for exceptional sound quality with a broad range of headphones, powerful enough to drive even demanding low impedance headphones (<32 ohm) including planar magnetics.
Highlights
- Unrivaled neutrality and soundstage
- Incredibly detailed and dynamic presentation
- Cross-Feed circuit - a revolutionary solution in tube amplifiers
- Virtually no background noise
- Beautifully hand-crafted
- Broad frequency response: 8 Hz – 75 kHz +/- 3 dB
- Premium driver tubes
- Improved noise reduction circuit
- High-end class power transformer
- 100% pure silver signal wiring in Teflon jacket
- Heavy duty Teflon gold-plated tube sockets
- High quality Mundorf and Nichicon capacitors
- Dale and Caddock resistors
- Preamp safety circuit
- Gold plated RCA inputs
- Extended 3-year warranty
- Input impedance: 100 kOhm
- Frequency response: 8 Hz - 75 kHz +/- 3 dB (300 ohm)
- Power output: 250mW
- THD: 0.4 % (300 ohm, 20 mW)
- Tube complement: Premium PsVane CV-181 Mk2 “Gold”
- Headphone output: 6.3 mm
- Dimensions (DWH): 11.6" x 8" x 6.5" (310x205x175 mm)
- Weight: 13.2 lb
What's In The Box?
- Beautifully hand-crafted tube amp
- Matched pair of driver tubes PsVane CV-181 Mk2 “Gold”
- Matched pair of power tubes 6N13S (NOS)
- AC cord
- User Manual
- Warranty Card
