{"product_id":"feliks-audio-envy-susvara-edition","title":"Feliks Audio Envy Susvara Edition","description":"\u003cp\u003eThe Feliks Audio Envy Susvara Edition is the most powerful Feliks Audio headphone amplifier to date, purpose-built for the most demanding headphones in the world. Based on the flagship Envy platform, this Class-A, single-ended, transformer-coupled tube amplifier was developed around one of the most celebrated pairings in high-end headphone audio: Feliks Envy and the HIFIMAN Susvara.\u003c\/p\u003e\n\n\u003cp\u003eThe original Envy was already known for its ability to bring power, scale, tone, and refinement to summit-fi headphone systems. The Susvara Edition pushes that formula further with up to 9 watts of output power, new gain settings, premium Stradi S300B power tubes, amorphous-core output transformers, and upgraded signal-critical components inspired by Feliks Audio’s 25th Anniversary Edition. The result is an amplifier built not only for Susvara, but for any headphone that needs serious drive, control, and musical authority.\u003c\/p\u003e\n\n\u003ch3\u003eDesigned for Susvara, Built for Any Demanding Headphone\u003c\/h3\u003e\n\u003cp\u003eThe HIFIMAN Susvara has a reputation for being one of the most demanding headphones ever made. It rewards amplifiers that can deliver real current, voltage swing, dynamic headroom, and control without flattening the character of the music. That is exactly where the Envy Susvara Edition is focused.\u003c\/p\u003e\n\n\u003cp\u003eFeliks Audio redesigned the gain structure with Low, High, and Susvara settings, with the dedicated Susvara mode delivering up to a 12% increase in power output compared to the Envy Performance. In practice, the Envy Susvara Edition outputs up to 9 watts of Class-A power, giving it the headroom to handle difficult planar magnetic headphones while still preserving the tone, dimensionality, and natural flow that make 300B tube amplifiers special.\u003c\/p\u003e\n\n\u003ch3\u003eMore Than a Power Upgrade\u003c\/h3\u003e\n\u003cp\u003eThe Envy Susvara Edition is not simply a louder Envy. Feliks Audio brought it closer to the technical level of the Envy 25th Anniversary Edition with upgraded output transformers, improved internal wiring, enhanced interference handling, and higher-grade signal components throughout the circuit.\u003c\/p\u003e\n\n\u003cp\u003eThat matters because high-end headphone amplification is not just about raw wattage. The best amplifiers control difficult headphones while preserving low-level detail, texture, dynamics, and spatial information. The Susvara Edition is designed to deliver that combination: more authority when the music demands it, and more finesse when the recording calls for restraint.\u003c\/p\u003e\n\n\u003ch3\u003eAmorphous-Core Output Transformers\u003c\/h3\u003e\n\u003cp\u003eOne of the most important upgrades in the Envy Susvara Edition is the use of custom amorphous-core output transformers. These transformers are designed to provide ultra-low noise, strong dynamics, and extended frequency response, giving the amplifier the bandwidth and control expected from a true endgame headphone amp.\u003c\/p\u003e\n\n\u003cp\u003eFor listeners, that translates into more effortless swings in volume, a quieter background, stronger bass grip, and a more open sense of space. It is the kind of upgrade that supports both technical performance and musical realism, especially with headphones capable of revealing every change upstream.\u003c\/p\u003e\n\n\u003ch3\u003ePremium Stradi S300B Tubes\u003c\/h3\u003e\n\u003cp\u003eThe Envy Susvara Edition comes equipped with carefully matched Stradi S300B power tubes, chosen for their precise, detailed, and airy presentation. A great 300B amplifier depends heavily on the quality of its tubes, and Feliks Audio includes a tube set that is ready for serious listening right out of the box.\u003c\/p\u003e\n\n\u003cp\u003eThe amplifier is also compatible with standard 300B power tubes using a 5V filament voltage, giving listeners room to shape the sound over time through tube rolling. That means the Susvara Edition can serve as both an endgame amplifier out of the box and a long-term platform for listeners who enjoy fine-tuning their system.\u003c\/p\u003e\n\n\u003ch3\u003eSignal-Critical Component Upgrades\u003c\/h3\u003e\n\u003cp\u003eBeyond the tubes and transformers, Feliks Audio upgraded several signal-critical parts of the Envy Susvara Edition, including capacitors, resistors, and internal wiring. High-precision components from brands such as Jantzen, Vishay, Nichicon, and Dale are used to improve signal clarity, repeatability, and overall circuit performance.\u003c\/p\u003e\n\n\u003cp\u003eFeliks also made additional refinements to tube parameter stabilization, tube-related failure protection, and the preamp output stage. The preamp section has been modified to reduce noise and better handle higher signal levels, making the Envy Susvara Edition a stronger centerpiece for both headphone and two-channel systems.\u003c\/p\u003e\n\n\u003ch3\u003eHandcrafted in Poland\u003c\/h3\u003e\n\u003cp\u003eThe Envy Susvara Edition is handcrafted by Feliks Audio in Lubliniec, Poland, with the kind of build quality expected from the brand’s flagship line. Its solid Wenge wood finish gives the amplifier a warm, architectural presence that matches its sonic character. Custom wood finishes may also be available by request.\u003c\/p\u003e\n\n\u003cp\u003eVisually, the Susvara Edition shares a clear family resemblance with the Envy Anniversary Edition, but replaces the piano-black finish with solid wood for a more classic Feliks Audio identity. It is substantial, elegant, and unmistakably built for a system where the amplifier is meant to be seen as much as heard.\u003c\/p\u003e\n\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eFlagship Class-A, single-ended, transformer-coupled tube headphone amplifier\u003c\/li\u003e\n  \u003cli\u003eMost powerful Feliks Audio headphone amplifier to date\u003c\/li\u003e\n  \u003cli\u003eDesigned as the ultimate pairing for HIFIMAN Susvara and other demanding headphones\u003c\/li\u003e\n  \u003cli\u003eUp to 9 watts of maximum output power\u003c\/li\u003e\n  \u003cli\u003eLow, High, and Susvara gain settings\u003c\/li\u003e\n  \u003cli\u003eSusvara gain mode delivers up to a 12% power increase over Envy Performance\u003c\/li\u003e\n  \u003cli\u003eCarefully matched premium Stradi S300B power tubes included\u003c\/li\u003e\n  \u003cli\u003ePsVane CV-181 Mk. 2 driver tubes included\u003c\/li\u003e\n  \u003cli\u003eCustom amorphous-core output transformers for low noise, dynamics, and extension\u003c\/li\u003e\n  \u003cli\u003eSignal-critical component upgrades inspired by the Envy 25th Anniversary Edition\u003c\/li\u003e\n  \u003cli\u003eHigh-precision components from Jantzen, Vishay, Nichicon, and Dale\u003c\/li\u003e\n  \u003cli\u003eImproved internal wiring and interference handling\u003c\/li\u003e\n  \u003cli\u003eModified preamp output stage for reduced noise and higher signal levels\u003c\/li\u003e\n  \u003cli\u003e6.3mm and 4-pin XLR headphone outputs\u003c\/li\u003e\n  \u003cli\u003eRCA and XLR inputs\u003c\/li\u003e\n  \u003cli\u003eRCA and XLR preamp outputs\u003c\/li\u003e\n  \u003cli\u003eSolid Wenge wood finish by default\u003c\/li\u003e\n  \u003cli\u003eHandcrafted in Lubliniec, Poland\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width:100%; border-collapse:collapse;\"\u003e\n  \u003ctbody\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eProduct Type\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eClass-A, single-ended, transformer-coupled tube headphone amplifier and preamp\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePower Tubes\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eStradi S300B\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Tubes\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003ePsVane CV-181 Mk. 2 \/ 6SN7\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eMaximum Output Power\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e9 W\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eInputs\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e2 x unbalanced RCA inputs, 1 x balanced XLR input\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eInput Sensitivity\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e1 V RMS\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eInput Impedance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e100 kΩ for RCA inputs, 10 kΩ for XLR input\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePreamp Outputs\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e1 x pair RCA, 1 x pair XLR\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePreamp Output Level\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eMaximum 5 V RMS at 600 Ω output impedance and THD \u0026lt; 0.5%\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eHeadphone Outputs\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e6.3mm and 4-pin XLR\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eAmplifier Impedance\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eLow: 3.8Ω at 32Ω load; High: 20Ω at 600Ω load; Susvara: 22Ω at 600Ω load\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eFrequency Response\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e7 Hz to 100 kHz +\/- 3 dB; 15 Hz to 43 kHz +\/- 1 dB\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eAC Voltage\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e115 V or 230 V, 50 \/ 60 Hz\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003ePower Consumption\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e110 VA\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eFinish\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003eWenge solid wood by default\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eWeight\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e15.1 kg\u003c\/td\u003e\n    \u003c\/tr\u003e\n    \u003ctr\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e\u003cstrong\u003eDimensions\u003c\/strong\u003e\u003c\/td\u003e\n      \u003ctd style=\"padding:10px; border:1px solid #ddd;\"\u003e35 x 33 x 18.5 cm\u003c\/td\u003e\n    \u003c\/tr\u003e\n  \u003c\/tbody\u003e\n\u003c\/table\u003e\n\n\u003ch3\u003eWhat’s in the Box\u003c\/h3\u003e\n\u003cul\u003e\n  \u003cli\u003eFeliks Audio Envy Susvara Edition headphone amplifier\u003c\/li\u003e\n  \u003cli\u003e2 Stradi S300B tubes\u003c\/li\u003e\n  \u003cli\u003e2 PsVane CV-181 Mk. 2 tubes\u003c\/li\u003e\n  \u003cli\u003eAC power cord\u003c\/li\u003e\n  \u003cli\u003eUser manual\u003c\/li\u003e\n  \u003cli\u003eWarranty card\u003c\/li\u003e\n\u003c\/ul\u003e","brand":"Feliks Audio","offers":[{"title":"Default Title","offer_id":42757168136263,"sku":"FLA-ENVY-SUS","price":16699.0,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/FeliksAudio-Envy-SusvaraEdition_11.jpg?v=1778182168","url":"https:\/\/headphones.com\/products\/feliks-audio-envy-susvara-edition","provider":"Headphones.com","version":"1.0","type":"link"}
