Dunu Falcon Pro In-Ear Headphones
Cup style
Wearing style
Driver type
Dunu
Dunu TopSound Falcon Pro Review - Mushy But Musical - Written review by Precogvision
10mm ECLIPSE dynamic driver
Falcon Pro packs tremendously powerful performance with its newly developed 10mm ECLIPSE dynamic driver unit. It adopts a DLC(Diamond-Like Carbon) Dome and fully independent suspension surround sound. The driver features a powerful magnetic system that produces a powerful magnetic flux of up to 1.6Tesla allowing for the swift, smooth movement of the diaphragm coil. ECLIPSE is a DUNU’s patented technology where the dynamic driver is designed with the best quality materials providing full-range support with quality detailing and high-resolution clarity. If you are looking for your next single dynamic driver IEM, the DUNU Falcon Pro might be a perfect choice.
Replaceable tuning nozzle design
Falcon Pro has a replaceable tuning nozzle design which allows the users to adjust the sound output as per their taste and preference. The pair comes with three different sets of replaceable nozzles, one for transparent sound, one for reference-grade sound, and one for atmospheric immersion. This is good to see DUNU introducing adjustable tuning with their IEMs.
High-precision CNC stainless housing
DUNU has created a bold look with the Falcon Pro earpieces. They are crafted using a high-precision CNC machining process from shiny Stainless Steel material with mirror chrome polish and sandblasted logo motif frosting. The earpieces not only look fantastic but also have an ergonomic shape for a comfortable fit for most users.
New Q-Lock Lite modular plug system
DUNU Falcon Pro comes bundled with a high-purity 6N Silver-Plated OCC Copper Cable with their self-patented new Q-Lock Lite modular plug system. They have newly developed this Q-Lock Lite for robust reliability without breaking the bank. Falcon Pro comes bundled with a full set of 3.5mm SE, 2.5mm Balanced, and 4.4mm Balanced termination plugs in the package. The cable has catch-hold MMCX connectors for an easy and stable connection with the earpieces.
Specifications
BRAND: DUNU
MODEL: FALCON (隼) PRO
NET WEIGHT: 19 g
FREQUENCY RESPONSE: 5 Hz – 40 kHz
SENSITIVITY: 112 ± 1 dB at 1 kHz
IMPEDANCE: 26 Ω at 1 kHz
TOTAL HARMONIC DISTORTION: < 0.3% at 1 kHz
ECLIPSƎ DRIVE MODULE
DIAPHRAGM: 10 mm diaphragm with amorphous diamond-like carbon dome and fully independent suspension surround
MAGNET ASSEMBLY: > 1.6 T External Ring-Type Neodymium Magnet
HOUSING
MATERIAL: Stainless Steel
INTEGRATION(S):
Dual chambered, anti-resonance shell design
Interchangeable tuning nozzles (Atmospheric Immersion, Reference, Transparency)
INCLUDED CABLE
LENGTH: 1.2 ± 0.1 m
MATERIAL: 6N silver-plated OCC copper
CABLE CONNECTOR: Patented Catch-Hold® MMCX Connector
PLUG CONNECTOR: DUNU Quick-Switch Modular Plug System (NEW)
INCLUDED PLUG TERMINATION(S):
4.4 mm TRRRS Balanced
3.5 mm TRS Single-Ended
2.5 mm TRRS Balanced
