Dekoni Audio Balanced 4.4mm Cable for HD600 Series
365-day returns
Dekoni Audio
Keep electrical noise to a minimum with Dekoni Audio’s new Cablez for Sennheisers HD600 series of headphones! Sporting a 4.4mm pentacon connector and 1.2M length, you’ll be able to find comfort in style.
The cable is a sleek, braided design for a clean look without the twists and coils caused by poor cable memory, and is the perfect length for use at your desk or on the go.
Using high quality 5N silver-plated copper and a gold-plated 4.4mm Pentacon connector, you can be confident in the corrosion resistance and durability.
Supported headphones include the Sennheiser 580, 58X, 600, 6XX, 650 and 660S.
