{"product_id":"dan-clark-audio-aeon-core-headphones","title":"Dan Clark Audio AEON CORE Headphones","description":"\u003cp\u003eThe Dan Clark Audio AEON CORE is the next chapter in one of DCA’s most important headphone lines. As the direct successor to the AEON 2, \u003cmeta charset=\"utf-8\"\u003eAEON CORE keeps the same core promise that made the series such a long-running favorite: reference-minded planar magnetic performance, a closed-back design you can actually live with, and comfort that makes long listening sessions feel effortless.\u003c\/p\u003e\n\u003cp\u003eAt $899.99, AEON CORE is built to be the new entry point into Dan Clark Audio’s modern reference lineup. It introduces a new planar magnetic driver engineered for efficiency, consistency, and repeatable performance, along with a revised tuning target developed in collaboration with Dr. Sean Olive. The result is a closed-back planar headphone designed to sound natural, controlled, and easy to trust from a wider range of sources than previous \u003cmeta charset=\"utf-8\"\u003eAEON models.\u003c\/p\u003e\n\u003ch3\u003eA New Driver for Better Consistency\u003c\/h3\u003e\n\u003cp\u003e\u003cmeta charset=\"utf-8\"\u003eAEON CORE uses an all-new planar magnetic driver stack built around three priorities: efficiency, tonal consistency, and unit-to-unit reliability. This is Dan Clark Audio’s most easily driven headphone to date, with 97 dB\/mW sensitivity and compatibility with amplifiers delivering at least 125mW into 16 ohms.\u003c\/p\u003e\n\u003cp\u003eThat matters because planar magnetic headphones are often associated with demanding amplification. \u003cmeta charset=\"utf-8\"\u003eAEON CORE is designed to be much easier to pair. It works comfortably with portable DAC\/amps, quality dongles, and desktop gear, while still scaling with better amplification when you want to push the system further.\u003c\/p\u003e\n\u003ch3\u003eAn Updated Reference Tuning\u003c\/h3\u003e\n\u003cp\u003e\u003cmeta charset=\"utf-8\"\u003eAEON CORE is the first Dan Clark Audio headphone tuned to a revised Harman over-ear target developed by Dan Clark in collaboration with Dr. Sean Olive. The goal was to better translate the original Harman research to today’s modern measurement systems, addressing the offset that appears when older target work is applied to current GRAS measurement fixtures.\u003c\/p\u003e\n\u003cp\u003eIn practice, \u003cmeta charset=\"utf-8\"\u003eAEON CORE is tuned to sound balanced, natural, and less forced than a typical “reference” headphone. Compared with prior \u003cmeta charset=\"utf-8\"\u003eAEON models, the voicing brings a slightly leaner upper bass, a gently lifted lower midrange, and a softer upper midrange. Vocals sit forward without turning hard. Acoustic instruments retain body and weight. Bass stays present and taut without overstating itself.\u003c\/p\u003e\n\u003ch3\u003eClosed-Back Planar Performance\u003c\/h3\u003e\n\u003cp\u003eClosed-back planar headphones are difficult to get right. They need isolation and control, but they also need enough openness and tonal balance to avoid sounding boxed in. ÆON CORE is designed to deliver the speed, low distortion, and clarity people expect from a planar magnetic driver, while keeping the practical advantages of a closed-back headphone.\u003c\/p\u003e\n\u003cp\u003eThat makes it a strong fit for desktop listening, office setups, travel rigs, and shared spaces where open-back headphones are not always practical. You get a more controlled listening environment without giving up the accuracy and resolution that define DCA’s planar designs.\u003c\/p\u003e\n\u003ch3\u003eComfort That Defines the AEON Line\u003c\/h3\u003e\n\u003cp\u003eThe \u003cmeta charset=\"utf-8\"\u003eAEON line has always been about more than sound. \u003cmeta charset=\"utf-8\"\u003eAEON CORE retains the physical design language that helped make the series so easy to recommend: DCA’s signature \u003cmeta charset=\"utf-8\"\u003eAEON earpads, a lightweight titanium headband, and a self-adjusting suspension strap that spreads weight naturally across the head.\u003c\/p\u003e\n\u003cp\u003eThe fit is secure, low-fatigue, and immediate. Whether you are listening for an album or settling in for a full workday, ÆON CORE is built around the kind of comfort that disappears once the music starts.\u003c\/p\u003e\n\u003ch3\u003eAEON CORE vs AEON 2\u003c\/h3\u003e\n\u003cp\u003eAEON CORE is the direct successor to AEON 2, but it is not just a cosmetic refresh. The biggest changes are in the driver, efficiency, consistency, and tuning target. The new driver makes AEON CORE easier to drive than previous AEON models, while the revised reference curve gives it a more current, research-informed tonal balance.\u003c\/p\u003e\n\u003cp\u003eFor listeners familiar with AEON 2, the shift should feel purposeful rather than dramatic for its own sake. AEON CORE keeps the closed-back planar appeal and everyday comfort of the series, while updating the acoustic foundation for better source compatibility, more consistent production, and a more refined reference tuning.\u003c\/p\u003e\n\u003ch3\u003eKey Features\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eClosed-back planar magnetic headphone from Dan Clark Audio\u003c\/li\u003e\n\u003cli\u003eDirect successor to the AEON 2\u003c\/li\u003e\n\u003cli\u003eNew planar magnetic driver stack engineered for efficiency and consistency\u003c\/li\u003e\n\u003cli\u003eDCA’s most easily driven headphone to date\u003c\/li\u003e\n\u003cli\u003e97 dB\/mW sensitivity\u003c\/li\u003e\n\u003cli\u003eWorks with amplifiers delivering at least 125mW into 16 ohms\u003c\/li\u003e\n\u003cli\u003eTuned to a revised Harman over-ear target developed with Dr. Sean Olive\u003c\/li\u003e\n\u003cli\u003eSlightly leaner upper bass, lifted lower mids, and softer upper mids compared with prior ÆON models\u003c\/li\u003e\n\u003cli\u003eNatural vocal presentation without upper-mid hardness\u003c\/li\u003e\n\u003cli\u003eTaut, controlled bass with reference-minded balance\u003c\/li\u003e\n\u003cli\u003eSignature AEON earpads for long-session comfort\u003c\/li\u003e\n\u003cli\u003eTitanium headband with self-adjusting suspension strap\u003c\/li\u003e\n\u003cli\u003eDesigned and assembled in the United States\u003c\/li\u003e\n\u003cli\u003eLaunch price: $899.99\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eTechnical Specs\u003c\/h3\u003e\n\u003ctable style=\"width: 100%; border-collapse: collapse;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eProduct Type\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eClosed-back planar magnetic headphone\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003ePrice\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e$899.99\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Type\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003ePlanar magnetic\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eDriver Notes\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eNew driver stack engineered for efficiency, tonal consistency, and unit-to-unit reliability\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eSensitivity\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e97 dB\/mW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eRecommended Amplifier Power\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eAt least 125mW into 16 ohms\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eTuning Target\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eRevised Harman over-ear target developed by Dan Clark Audio with Dr. Sean Olive\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eDesign\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eClosed-back over-ear\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eHeadband\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eTitanium headband with self-adjusting suspension strap\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eEarpads\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eDan Clark Audio ÆON earpads\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003e\u003cstrong\u003eManufacturing\u003c\/strong\u003e\u003c\/td\u003e\n\u003ctd style=\"padding: 10px; border: 1px solid #ddd;\"\u003eDesigned and assembled in the United States\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"Dan Clark Audio","offers":[{"title":"2m 1\/4\" and 3.5mm DUMMER","offer_id":42842183893063,"sku":"CORE-ST001","price":899.99,"currency_code":"USD","in_stock":true},{"title":"2m 4-Pin XLR DUMMER","offer_id":42842183925831,"sku":"CORE-ST002","price":899.99,"currency_code":"USD","in_stock":true},{"title":"2m 4.4mm DUMMER","offer_id":42842183958599,"sku":"CORE-ST003","price":899.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1791\/0383\/files\/Core-001.jpg?v=1780509931","url":"https:\/\/headphones.com\/products\/dan-clark-audio-aeon-core-headphones","provider":"Headphones.com","version":"1.0","type":"link"}
